1976 A/C Heater Fan Upgrade
There have been several threads about upgrading the C3 A/C Heater motor/fan with a C4 unit. My question is will any C4(1984-1996) work or is a specific year required or better? I plan to upgrade my 1976 coupe. Wilcox Corvette has a unit for $73 and I found a 1985 unit at Carquest for $60. Does anyone have a recommendation.
Received 1,469 Likes
Cruise-In II Veteran
You need the C4 squirrel cage and a homemade spacer. Your C3 motor will be fine.
if the c3 motor and the c4 motor are the same speed ( i dont know for fact)..you are better off with the c3 motor because the c4 blower motor has a smaller hole for the cooling fan tube (i had never read that before)..i couldnt get the cooling tube right, luckily i still had the c3 motor and the holes were different, the c4 being too small... i used a step bit to enlarge the diameter of the c4 motor...
I recently replaced by C3 motor with a C4. Motor vent fit fine, bolted right up to the box. I kept the C3 squirrel cage so I did not need the spacer. I used the two wire C4 motor, just have to make sure you correctly wire it up or the fan will rotate backwards.
Last week I went out and bought the upgraded "84 - 86" vette motor/ squirrel cage from NAPA. About $50. Made a spacer out of 7/8 oak I had lying around. Fired it up and I thought my arm was going to be sucked into the vent intake! Unbloody believable how much more air is being moved! I have taken the car out even in -40 weather ( highways have to be clear though) and I've always worn a heavy mits and a toque. I'm thinking with this much air flow - I might be able to just wear a T-shirt !
Hats off to the fellow that discovered this upgrade !
thegazman
The improvement is in the fan design for increased air flow, not the motor.
The removal / replace probably took me 10 mins. The spacer took me about an hour.
Sorry - can't help you there. I don't have AC. The radiator overflow tank has to come off. Reach in behind the passanger front tire, locate the 2 lag bolts that hold it to the inner fender, remove. Next ,locate the 6 bolts that hold the fan motor and squirel cage onto the firewall. Remove. Make a template out of paper. Transfer that paper template onto 7/8" oak. Get yourself some #8 x 1.5" screws and put the new motor / squirel cage with the new spacer you just made back together.
1 Post
before you go and do all that, just get a bigger ground wire to your motor and it will increase the speed of it quite a bit. I went with one gauge bigger and there was a huge difference in air flow. If you don't think this is enough, then go with the c4 setup.
I did the ground wire too and it did help some. The REAL answer is the '84-'86 motor. And I thought it'd be a PITA too. Nope. Just a nice little project. At least take your old one off and make a template and work on a spacer. 5 mins to take it off , make a template- 5 mins to put it back on.
