Pics of Dash/Console Wiring Harness
I am in the process of putting my console and dash back in my 75 and need to see some pictures of how the wiring harness is routed. If you have any, please post them. Thanks
The harness goes over the speedo on the left side (there is a large clip on speedo) and across to the tach under another larger clip and down the right side of tach to the center cluster. There is one large tail that drops between the speedo and tach for the column and kickdown connectors.
Here is a pic from my 73 restoration and a link to some other pics I've taken. just let me know if there are any other areas you need pics as I have about 1000 on file.
Link: http://s286.photobucket.com/albums/l...ion/?start=all
The biggest issue I am having is making sure I have the harness in the right position with the duct work in place. I know how it runs along the top of the speed/tachometer but what about where the harness runs down for the AC/Heater controls, shifter console, and power windows?
I appreciate you guys help and hope to have this knocked out soon but seems like a previous owner was in there before me. I
Would I be better off going ahead and installing the left hand(tach/speedo) first and then routing the harness around it before trying to install the gauge cluster, shifter console, etc?
Don't know if this will help, but once this far, it should be simple to lay out.
The taped harness part lays on the tunnel from the drivers side to the pass side and then runs under the console toward the rear.
Thanks Noonie. That pic is exactly what I needed. I think my harness is pulled over to the passenger side too far due to moving it alot during carpet install. The harness is being a PITA to work with right now due to the colder temps we are having. It is suppose to be up in the mid 60's tomorrow so hopefully I can pull the car out in the driveway and let the sun shine on the harness for a few hours before I attempt to route it. Thanks to everyone for the help.
Received 1,469 Likes
Cruise-In II Veteran
Tim, the assembly instruction manual (AIM) helps a bit. The routing could vary between model years, so it would be best to check the 75 AIM.
After struggling with the harness my 68, I removed the speedo and tach from the panel and then pushed the panel into place. With the speedo and tach removed I could see areas of interference with the harness and I could reach through the speedo/tach holes to move the harness around. I did this with the steering column removed. Working with the interior/firewall harnesses, etc is so much easier with the column removed. It's relatively easy to remove and reinstall the column.
I now have the interior and steering column of my 70 removed. I've got a lot of work to do to get it back!!!
SouthCarolina77 (08-08-2020)
Dembo,
How does the cable that runs from the right side of the heater/ac control to the top of the heater box route? Does it go behind the windshield defrost duct or does it go further back and follow the routing of the vacuum tubes that connect to the controler?
Hey Tim,
I don't have a good picture but I routed mine as follows and I think it's consistent with the AIM.
The AC harness follows the vacuum hoses. Both come in on the passenger side (next to the wiper motor) through the firewall. They then route downwards behind the heater box and come out below the black box which directs air to the feet. (it clips on the heater box). Basically the harness & vac hoses are then 'resting' on the transmission tunnel. The go over the metal bracket which is there to secure the shifter console at the front to the heater control panel. The AC harness also plugs in to the instrument panel harness. This harness should have a plastic clip taped into it and this clip plugs into a hole on the right hand side of the same bracket (to fix the shifter console). So the instrument panel harness goes down over the tach, upto the transmission tunnel, over and parallel to that bracket. The instrument panel branch going to the RH side lies on the transmission tunnel but stays in front of that bracket (in between the bracket and the heater box). The gauge cluster wires (lamps,gauges) come out of the instrument panel where it's going down over the tach and on mine they are between the LH dash pad and the din radio bezel.
It's difficult to explain without pictures but I gave it my best shot
Nick
Edit : I just reread your question lol The controller cable follows the vacuum hoses meaning underneath the black box for feet heating, but I can't remember if it goes all the way to the firewall or if it comes up before, parellel with the heater box. I think I routed it as shown on the picture (the dotted line is where it goes behind / underneath the feet heater duct)
Nick
Hey Tim,
Nick
Nick
After having pulled my dash about 3 times....
The last time I did it, I went ahead and added 2 combo connectors to every lead on that harness. I soldered every lead to avoid future connection problems.
So now, I just disconnect 2 connectors and then work on pulling the dash.
I kept deferring because I told myself that I'd never pull the dash again....but the 3rd time I just soldered in the combo connectors to make my future experiments easier.
