1972 project car home finally
Just posting some pics of my new project. Will be a little while before I start it, but I thought I would post some pics as it is now. I am sure there will be a lot of questions coming once I start
I have all the parts that should be on the body, just not on the car. Add plan on doing a body off restore and blast the frame to remove the surface rust and go up from there. The body related paint removal will probably be subbed out but not sure yet.
That is quite an impressive challenge, I am always awed by you guys that can do that kind of work.
Are you going to do most of the work in your garage at home or do you have a separate shop?
What are your plans, NCRS stock, nice driver, vintage racer, all out rod?
Eric.
restore
I am going to do as much as I can in my garage. I have a 3 car garage so that may help some.
I have never taken on such a large task, but I think I can do it. And am very **** about things so that will be a plus.
as far as what II am going to do to it, not sure 100%. I know there will be some sort of engine work, maybe a crate engine to get 350ish hp or change out parts on the existing to get the same hp. I do plan on side pipes and try to keep the interior as it was.
I do plan on doing the chassis myself, but not sure how I am going to get the body off, dont want to rig a sling that may hurt the body, and doubt my friends will volunteer the lifting help
my wifes 96 interior redo is what got me thinking about this. my wife is the one who this will be for when done, but I get to do it however I want. was going to do another type of car so I could blast the body my self also, but she wanted this one. it helps that I wont as many questions since it is for her
God bless those of you with all the time, money, vision & patience
Take lots of pics (digital cameras and on line photo hosting!)
...I know there will be some sort of engine work, maybe a crate engine to get 350ish hp or change out parts on the existing to get the same hp. I do plan on side pipes and try to keep the interior as it was...
And watch out for the "zipper effect" or the "while I am at it" syndrome! I stopped myself before putting wheel flares on mine, but I still kind of look at mine and squint! Wishing it had flares, maybe the next reincarnation.
...I do plan on doing the chassis myself, but not sure how I am going to get the body off, dont want to rig a sling that may hurt the body, and doubt my friends will volunteer the lifting help...
Good luck and have fun! Eric.
Received 2,878 Likes
Hi ef,
I agree with Glenn that your car looks like a good beginning for an extensive project.
Lifting the body isn't as scary as people think... just a good bit of work. What you gain by doing it though is worth the work.
Pictures!!!
Regards,
Alan
PS: If I were you I'd put everything back together now and then disassemble the car.
This way you'll know how everything fits. Too often people post that the car is painted and now they realize for example that the bumpers don't fit well.
Pictures!!!
Regards,
Alan
I'm in the same boat as you. I started off with one thing and it exploded. Now there is nothing on my car except the empty shell and a steering column. I'll be pulling the body off as soon as the weather cooperates. It's pretty overwhelming at this point. Hope I remember where everything goes. I always hated working on cars because I was on a time frame to get it back on the road for work. Knowing this will be done when it is done is pretty relaxing.
I'll be checking in on your posts keeping track of your project. Have fun.
Just noticed you aren't far from me at all. I'm in North Arlington. If you need any help on something let me know. I know how hard some of these things are to do by yourself.
Looks like a great project. A few recommendations from my experience.
Take lots and lots of pictures during dis-assembly as they will be a great reference when you start putting it back together a couple years from now.
Label and bag all the parts you can as you will forget where some parts came from and from my experience bag them as soon as they come off. I would find bolts on my bench that I put down and didn't bag and a week later couldn't remember where they came from.
You may want to get a complete chassis bolt kit for your car (stainless would be great) as it will avoid countless trips to the hardware store or lots of hours blasting and repainting.
Get a bunch of large plastic stack-able bins. I got opaque ones with hinged covers and log in a spreadsheet what goes is in each bin. I can't tell you how many times I went through bins looking for one part that I needed because I didn't log where things went. Eventually I sorted what went into the bins based on a category such as : interior, suspension, body, engine bay etc.
I sent my frame out for blasting and powder coating. I should have also sent all the suspension parts with it as they took a lot of my time to blast and paint and relatively cheap if done as a batch.
You may consider sending the body out for soda blasting unless you feel that you want to do the razor blade method of stripping. I wouldn't have the patience for doing it an inch at a time.
Have fun and we will look forward to your progress pictures!!
