Rebuilding trailing arms on my 1969, need a little help
Last summer I sheared a rear spindle in my passenger side trailing arm. I received all the replacement parts yesterday and was going to drop everything off at a local mechanic to assemble everything for me tonight after work. I purchased parts to do both sides right away (spindles, inner/outer bearings, races, spacers, shims, nuts). Here is where I need your help. I disassembled the trailing arms, the inner bearing slide on and off the old spindle real easy. I can not get the new bearings to slide on the new spindles, the new / old bearings have the same part number. I know that the outer bearings have to be pressed on/off. Should the inner bearings slide on/off the spindle just as easy as the old ones or should they have to be pressed on like the outer bearings? Not sure if I should call the place where I purchased them from or take some emery cloth to that side of the spindle (inner)?
Jabo
Jabo
Cruise-In IX Veteran
All the bearings for the rear are press fit from the factory. It sounds like someone sanded down the old spindles to make them slip fit. Either way works.
I was a little worried about dropping them off and having the mechanic complain that there was an issue with the spindle.
Which might be why the old ones failed. The more I read on this topic the more I will stay with the factory tight fit.
