1980 Rivet and Sealer Qs
Just got my car back from full paint job...
Need to know what size or type rivets I need to purchase to re-attach the water deflectors in the door jambs. Also would like to know if some type of sealer is needed underneath the water deflector before installing? I make the assumption also that I can just purchase them from a local hardware store (Menards, Home DEpot) along with manual rivet tool??
Also, what type of rivet to use and sealer on the chrome T-top trim that is on the top of the vehicle. I removed this piece and drilled out the rivets on both back corners.
Thanks,
TTERZ
Thanks,
TTERZ
1 Post
Just did the same thing with my 79. Should get it painted in the next week or two. I am also wondering about the sealer under the deflector. I will just use the manual rivet tool and probably put some RTV under it.
Is there a certain style or size/depth rivet that is needed for deflector and for top chrome trim piece by the edges of T-Tops?
Any help would be appreciated.
TTERZ
TTERZ
Received 1,468 Likes
Cruise-In II Veteran
My Corvette Illustrated Parts Catalogue shows 1/4" - 3/8" x 3/16" for the rivets; same for t-bar and diverters.
If a sealant was used, the AIM will show it and list a description (or a part number) which may or may not help. Clear silicone would do in a pinch.
Easy Mike,
THANKS....EXACTLY the information that I was looking for. Also, for the record, I will be purchasing an AIM soon so that I can possibly lookup this information as well.
Thanks again,
TTERZ
Thanks again,
TTERZ
