79 high speed blower motor fuse location
Looking for my in line fuse to my blowermotor cause my high speed isn't working on my a/c.
Does anyone have pics or accurate description?
Received 1,468 Likes
Cruise-In II Veteran
It's likely to be the blower motor resistor on the case. Fan speed is controlled by the resistor. Willcox lists them: http://willcoxcorvette.com/product_i...oducts_id=8646
I'm pretty surer all speeds are except high speed work with resistors from the looks of this diagram.
http://willcoxcorvette.com/instructi...ng_78-82_2.JPG
All other speeds work just not high speed
There is no high blow fuse,high speed uses a relay,its usually the relay that goes bad but it can be dirty connections or a bad ground to the relay.
Check the 12 red at the relay for power
Make sure the relay is grounded
Check that the orange is hot in high blow position-(the orange trips the relay)
