cost of body work paint job on 1972
I am looking at a 1971 coupe that has a couple of stress cracks in hood and near the door handle. also the paint job is older. What is the cost of body work and paint jobs on a corvette? also this would be my first vette. thanks
Steve g
As Steve noted I would guess at least $5000 but most likely much more IF you get it painted my someone who has experience in painting older Corvettes before.. From memory just puffing out the final coat took about 40 hours of labor. on the last Corvette I had painted (show quality paint job however)
Bob G.
Bob G.
Received 1,469 Likes
Cruise-In II Veteran
Who will be doing the work? If you can do the work, you save money.
If you will not be doing the work, you will be paying for the expertise of others.
Once you have the car, you can get estimates.
Can you do any of the work on the car to knock the price down ? You will be amazed at what you are capable of doing after getting a few estimates. Try a small repair yourself. Take your time and see how it comes out. Build confidence, and do one panel at a time. Labor and materials arent cheap. I am going to paint mine at home. Been working on the body since last year, currently block sanding it. Picked up my paint the other day. This little box cost a small fortune. Good luck.
Since, you are looking at this car factor in what it will cost you to have it painted verses buying a nicer car with good paint, interior an good mechanical
