Z07 option
This car has been under NCRS nut/bolt restoration since 2004. Presently the car is apart/ frameoff. The no hit body is on a body castor and the frame has been blasted and repainted with GM104. The motor has just been completed and is presently having all the accessorys installed.
8th Gear
Gm-104 factory asphalt based paint
The cost is approximatly $100.00 per gallon. I think you can do the entire frame with one gallon.
It's not the most glamousous, but it is correct.
Pete
8th Gear
Z07 Survey.
....I do not believe you could get an automatic with Z07.
...you could get other rear end ratios with the Z07.
....4 of 6 Z07s I have seen had A/C.
....you must have a fairly late convertible and your claim is probably pretty legit. I had a '75 L-82 coupe VIN#35026 that was a July 12th build date car and the LAST 1975 roadster(White/Red interior L-48 automatic car)was VIN#35199 and had to have been a July 13th or 14th build date car.
...I had to dig through my '75 L-82 Corvette Survey that I did from about 2000-2008 to find some of this info. I have something like 68 out of 2372 cars. A small sampling I know, but I have some fairly neat info.
Lack of time and mostly lack of money the restoration is going slowly. Any help is appreaciated. Thanks Cleveland
I am the soon to have at my home owner of a 1975 Corvette stingray coupe L-82 4 speed born in april of 75. Vin number confirms l-82.VIN 1Z37T5S421389 Body 182 10L Body code confirms color as white and black leather interior.
I saw some one call the M-21 a bog warner.. It's not it a Muncie M-21 chevy stopped using the because the s-t10 came out that was made by borg warner.
I will do everything I can to find the build sheet once she comes home.
I am confident it is one of the 1057 m-21 cars built. That only came with the L-82 engine. a good number of the L-82 motors came with autos.
My car does have the a/c option and power windows and am/fm radio. Oh my sugar is a barn find from southeastern wisconsin.
I had heard that 3:73 rear axle gears came in Z07 cars possibly also. Any ways 1-1057 ain't bad at all.
Dual exhaust with headers and a cam already in it. God to goo....fast.
