Coil & coil bracket fit on a ZZ4
Searched an nothing came up.
Now, I can't be the only one with this problem. You cannot put the coil on with the original bracket with the HEI distributor. At least I can't. When you go to line up the 2 bracket bolts, the coil hits the distributor. What am I missing.
Duh, that's what I was missing. I was figuring to install the old coil but forget these new "modern" HEI units have them built in.
