American Racing Outlaw II's
Considering a new set of inexpensive rims, would prefer chrome but $'s tight with the lil' baby and all...
Will these require spacers?
I'd like for my new rims to stick out just a bit further then stock rims, say 1/2" or an 1", just a different, more aggressive stance...something different...
Here's the specs:
Front and Rear
Offset: -19mm
Backspacing: 3.74"
Bolt Pattern: 5-475
(Silver Machined w/Clearcoat)
American Racing Outlaw II (Silver Machined w/Clearcoat)
Found them on tire rack . c o m for $100 each...
Figure that sounds reasonable..
Kevin
Here's the specs:
Front and Rear
Offset: -19mm
Backspacing: 3.74"
Bolt Pattern: 5-475
Kevin
I actually like that style of rim and think it would look great on a vette. You may want to check out Ebay as you can find some good new rim deals on there.
I can't comment on the specs but I'm sure others will chime in shortly.
I like your rims better then the ones I had settled for...
Will: http://www.summitracing.com/parts/ARE-235765/?rtype=1 work with my 255 60 - 15 Firestone Firehawk tires? Fitment wise or are they too wide for a 7" rim?? My rims that are on the car are 8"
Kevin
Kevin
oK OK, I see now that they sell them in 15X8's...
Are these the exact ones that you have on your car, shown in the picture??
http://www.summitracing.com/parts/ARE-235861/
Kevin
Kevin
Kevin
Kevin
The one's that Summit shows in the picture I believe is a generic picture right? If I order them they'll be same as yours, 5 lugs, small center cap, not that big ugly center cap right??
I figure they posted the truck version (8 lug) as a general pic..
Kevin
Kevin
