1976 Aluminum Radiator and Elec. fans ??
Hello Corvette Forum...
I was changing my radiator hoses on my recently purchased 76 L82 Early. Busted a hole in the radiator trying to lift the shroud to get the lower hose installed.
Flipped out and ripped the shroud out in a million pieces. Went online to find out the shroud on a 76 early can cost close to a dime.
My father-in law has a 57' rag-top and he runs an aluminum radiator with electric fans.
My question is has anyone done this and had any problems or can point me in the right direction before I jump in?
Thanks for your help.
Me, being a cheap *** 11 years ago, I had the stock radiator recored with a 4 tube BB core and put an electric 16" Permacool fan on it. I fabricated the mounting brackets rather than use the ties through the radiator. No problems cooling my modified 383.
BTW, mine is an early '76 L-48.
Dewitts is the way to go for aluminum.
I am going to see if there is a radiator shop that can save the mess I made of this thing and I will do the same thing. GREAT IDEA!!
Radiator
Well, found a radiator man to save my brass!!
Now I need to get the electrical fan set-up.
I will order the dual fan kit from Dewitts or if I find one equal for less.
Best way to wire the fan in?
Thanks for your help and hope to see you all at Carlisle.
Lastly, anyone have a 73-76E radiator core support?
