Pictures of Fuel Lines, Return Line, Mechanical Pump Set Ups
Hello,
I am running a Holley and have the original two fuel lines coming up to the motor, one is the feed, one is return.
Where should I run the return line off of? the fuel pump will have two fittings correct? one for the feed to the pump, then one going up to the carb...where should I tap off to connect back to the return.
Also any recommendations for a nice, stock looking, high or higher volume than stock mechanical pump?
I know you guys posted pics when I posted in my last thread about pumps, would like to see other detailed pics if you guys have them.
Thanks, Tim
Thanks, Tim
I think for your year the return comes from the fuel filter, later years had the return from the bottom of the fuel pump.
Nick
Go to the zip page, it has a schematic on the RH side http://www.zip-corvette.com/ProductD...R-SR&CTitle=&#
Nick
I do think that is it, anyone have a line on a cheaper unit? I am trying to put this car together dirt cheap, don't need an actual AC brand. Maybe I can just get an autozone cheapie....paint it flat black or something.
I also would like to find a dual feed line set up similar to this Chevelle one, but close to what the Corvette would have in 1970 (though my car is 69)
I just dont want anything too flashy.....I know the factory lines are 5/16? but will need the lines to fit an aftermarket type 4777 Holley
