Did I test my alternator correctly?
Hi
Was wondering if I tested my alternator correctly?
The alternator has one red wire at the back and a plug with two wires at the side.
I turned the engine on grounded the multi-meter and connected the positive to the red wire. Only got 12 odd volts from it, same as when the engine is off
Nope...close but no apple
I don't know the year you have, but most of them have a integrated regulator {built in}.........some plugs are in the rear and others on the side of the case...by making a jumper from the battery post {big red wire or red post} to the plug 2 wires and connected together, start the engine and if the alternator is good the volts should jump to 13-14 if your using a volt meter...no meter...then listen to the alternator..it should sing to you indicating it WORKS......
I'd have to look up the wiring diagram for an external reg to give you the reg bypass for that. Can't remember off hand.
You don't need to check charging at the alt, it can be done at the batt. Quick check charging voltage should be .5V higher at start than batt voltage at rest and with a fully charged battery after the system has stabalized should be around 14.2-14.5V.
Steve g
