Rear Swaybar - Poly bushing installation
Received 3,138 Likes
Installing the harder poly bushings in the rear swaybar
Old and simple method, but in-case it helps someone
Removed the inner sleeve, greased everything with the poly grease (with dreams of no squeaks down the road)
For the link, 1" socket and the vise, line everything up and they go in quite nice
For the bar it's self
A piece of threaded rod (long bolt with lots of thread would do), one fender washer, one regular washer and the 1" socket
If it starts to move sideways, just press it back in-line with your thumb
Pops in the last little bit
Grease and push the sleeve back in
About 20 minutes playing with the vise, c-clamps, hammers, arbor press
About 1 minute this way
Mooser
Mooser
Well, the poly vs rubber question is right up there with blond vs brunette, small block vs big block, etc. Everyone has an opinion and everyone who disagrees with them is wrong.
Here's my thoughts and how they apply to MY situation.
I'm driving a boulevard creeper that spends most of it's moving life in town or making short trips between towns. I like a smoother ride over a harsh one. That being said I don't want my vette to drive like a couch either.
All bushings that I figure are more directly transmitting vibration, shock, etc to the frame I've gone with rubber. (T/A, Diff mount, Trans mount, Spring cushions, etc)
All bushings that are mainly pivoting I went with Poly (Lower control bars, sway bars, etc, I know the T/A pivot but they also twist and do other things)
The hope being that I get the mushy ride under normal driving and a slightly improved response on the cornering.
If it doesn't work out, I'll got back to rubber on everything.
Mooser
My $.02, actual mileage may very, professional driver on closed course, results not typical
Mooser
It works Great
Installed my poly bushings this evening, thanks to your post. It worked great. Besides your tips, the main thing is to make sure you get everything lined up straight so it doesn't bind as you try to push in. First one went in no problem. Had to fight the second one for a bit but it wasn't over 15 minutes and I had both in. I plan to remove rear sway bar and as I feel this will be MUCH easier with it out. Will paint and grease it since its out. Thank you much.
Here is a photo of my set up .
I just did mine this week too in poly. Used a press on the links and the vise on the bar. Worked well. Just added the 1 1/8 front and the 7/16 rear. No rear before and a 7/8 front. On my short test drive I liked the handling difference.
What have you guys found about the handling?
Mooser
Mooser
Rogman
I changed / updated a bunch of stuff on the rear at the same time (bearings, shocks, u-joints, etc) so it's hard to say what had what effect but I am (was) happy with the changes, seems to have done what I wanted. All that little stuff adds up
M
M
interpon (05-03-2020)
