Battery drain
Battery drain
My battery keeps draining out. Can't be the alternator as it drains out just sitting in my garage. Initially thought it might be a light that did not turn off, but there is nothing (at least visual) that points to where the leak might be. Any idea's on how to start trouble shooting this would be super helpful.
It started about 2 weeks ago, no work done on the car at all of late.
-D
-D
I had same problem. My interior lights would not time out so I removed the bulbs. It still drained the battery. Put the volt meter between the batteries pos terminal and the battery cable and it showed a draw of current, my courtsey light timer is located in the wiring bundle between the tach and speedo so I pulled the courtsey light fuse and installed a battery disconnect switch.
I had a problem like that and it was my headlight switch. It was draining my battery if the **** was all the way up. I had to turn the light in the instrument cluster off to avoid a dead battery the next day. Visualy no light was on but the current was leaking just enough to drain the battery.
Knuckles, do you have a multimeter? If so, set the meter to read "current", put leads into appropriate holes on meter. Disconnect negative battery lead and place the meter between the negative battery terminal and the negative battery lead. With the meter turned on you will probably see a reading that shows a current draw (a 12v light bulb in place of the meter would also work - light on current/light off no current). Now the fun part.....start to pull a fuse, then shut the door and see if your meter reading goes to zero. If not, try another fuse. This process of elimination will eventually get you to the circuit that the drain is on......making it easier to isolate and troubleshoot.
Hope this helps
Brian
Hope this helps
Brian
Hope this helps
Brian
Hope this helps
Brian
Weird, I may be experiencing the same problem. I just got my car out of winter storage and the day I picked it up, it fired right up no problems. I went to drive it a few days later and ZERO. The battery is only a year old so I jumped it and the car fired right up. Now, it's at the shop and the mechanic keeps telling me the samething, he charges the battery and it starts right up, but if it sits, nothing.
I will pass this info along to him. Thanks guys.
Very common problem with Corvettes...I took the lazy way out and just put in a battery disconnect..
Thought I was already to go, thought I had the "dead" battery issue solved. NOPE! Now going through the process of checking each fuse etc trying to find where the draw is coming from. I love my car, I love my car, I love my car.
St. Jude Donor '07
Sorry, but you can't rule the alternator out like that. An alternator produces AC current that must be rectified to DC for your car's electrical system. To do this, every alternator has a bridge rectifier made up of a number of diodes, which are one-way electrical valves. If one of those diodes goes bad, and they do, electricity can leak in the wrong direction...and drain your battery.
Knuckles hasn't been back since first post....
I had a battery drain last year. Turned out to be my starter- charge battery and was fine- let it sit over night and nothing- hook a jump starter to the vehicle and it would fire right up. One of my indicators also was that my vehicle after driving on a hot day- let it sit for 20mins and the vehicle would not start- the starter would not even turn over- hook jumper cables to it and bam0- starts right up. Replaced the starter and all is well
71Vette - Got super busy at work and did not get a chance to update , I did not sell it and it did not burn down - although I have had a fire in the past!!
Not a battery drain problem , I think this is a starter problem. The battery has a full charge, its a brand new optima. I can hear a click when I turn the ignition key. Ocassionally it would start up and then just stop working. Now its down for good!
Going to replace the starter next week and will update then.
-D
-D
Bad starter solenoid.
