Anyone besides Alan71 make a list of Matching/Correct Numbers? Here's mine...
Old 05-04-2012, 09:25 PM
xCCTer
CF JASOC Member
Support Corvetteforum!
xCCTer's Avatar
Location: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Default Anyone besides Alan71 make a list of Matching/Correct Numbers? Here's mine...
1971 Chevrolet Corvette Sport Coupe (37)
VIN - 194371S106XXX
Body Build Date - Jan 9, 1971 (F09)
Ontario Orange (987)
Deluxe Black Leather Interior (403)
Power Windows (A31)
Air Conditioning (C60)
Power Brakes (J50)
Tilt/Telescopic Steering Column (N37)
Power Steering (N40)
F70-15” White Lettered Nylon Tires (PU9)
AM-FM Radio (U69)
Four Speed Wide-Ratio Base Transmission (ZW4)
Custom Interior with Leather Trim
350 Cu.-In. Turbo Fire 350 V-8 270hp
4-Speed (2.52:1 low) 3.36 Rear
Engine Casting - 3970010 Date - L120 (Dec 12 1970)
Engine Stamp Pad - C11S106XXX V1229 CJL
(St Louis Assembly Plant, Flint Engine Plant, Dec 29 1970 - 350/270 4-Speed)
Axle Code - LRW 213E2
(Warren Axle Plant, Julian Date 213, Eaton Positraction, 2nd shift)
Muncie M20 HD 4-Speed (3925661) - P1T21A (Dec 21 1970) C11S106XXX
Cylinder Heads - 3973487 Date - L280 (Dec 28 1970)
Intake Manifold - 3973469
Exhaust Manifolds - 3846559 (RH) 3989036 (LH)
Carburetor - Rochester MV4 - 7041213 DM Date 2310 (231st Day 1970)
CEC Solenoid - 1114444
Distributor - 1112050 Coil - 1115270
Water Pump - Not Original
Alternator - Not Original
Starter Motor - Not Original
Windshield Wiper Motor - 7044758 352 0 2 A
Windshield Glass LOF Date - AT (Sep 1970)
Passenger Door Glass LOF Date - VT (Dec 1970)
Driver Door Glass LOF Date - Not Original
Removable Rear Window LOF Date - AT (Sep 1970)
Lap Seat Belts - C-13 48L90 Not Original
Shoulder Seat Belts - C-24 34B70
Brake Master Cylinder - Not Original
Horn (1) - 9000245 03H (Aug 1970)
Radiator Fan - 3991427 H70 (Aug 1970)
Radiator Fan Clutch - 9 15 70 SC
A/C Compressor - 5910741
Not done yet...
Old 05-05-2012, 07:21 AM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi Mark,
I noticed your windshield date.
(Relatively early).
Is it LOF SAFETY PLATE, or LOF SAFETY FLO-LIGHT?
Regards,
ALAN
Old 05-05-2012, 09:21 AM
Easy Mike
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Lucky you. Your car was built after the strike so lining up numbers is relatively easy.
My fiancee's 71 was set to be assembled in September with all the appropriate August/September dates and codes on the engine.
Due to the strike, the time/build code is December 3.
Old 05-05-2012, 09:43 AM
xCCTer
CF JASOC Member
xCCTer's Avatar
Hey Alan,
It says Shaded Soft Ray, and then below that, Safety and Plate on either side of the LOF logo.
Mark
Originally Posted by Alan 71
Hi Mark,
(Relatively early).
Regards,
ALAN
Old 05-06-2012, 11:50 AM
xCCTer
CF JASOC Member
xCCTer's Avatar
btw,
What's the difference?
Old 05-06-2012, 03:45 PM
Alan 71
Alan 71's Avatar
Hi Mark,
My understanding is that the difference is in the manufacturing process.
In Safety Plate, (PLATE), each piece of glass is made individually.
In Safety Flo-Lite, (FLOAT) the glass is made in long continuous lengths that is then made into individual windshields.
The second method is a more economical method.
Regards,
Alan
Old 07-29-2013, 11:57 AM
xCCTer
CF JASOC Member
xCCTer's Avatar
Did not know that.
Old 07-29-2013, 01:51 PM
73L82AIR
73L82AIR's Avatar
Thats an interesting piece of info
Old 07-29-2013, 03:35 PM
Alan 71
Alan 71's Avatar
Hi 73,
Not only is it interesting... you can trade that info for a free Big Mac at any participating McDonalds. But, only at the drive-up window.
Regards,
Alan
Old 07-30-2013, 08:29 AM
gluvnaa
gluvnaa's Avatar
Here is my list for the 69 Vert. I like Excel better for storing data/links. I have my documented history and other info in separate tabs.
To Anyone besides Alan71 make a list of Matching/Correct Numbers? Here's mine...
Quick Reply: Anyone besides Alan71 make a list of Matching/Correct Numbers? Here's mine...
