72 LT-1 Intake manifold bolts
Old 05-15-2012, 03:42 PM
garage-ghost
garage-ghost's Avatar
Default 72 LT-1 Intake manifold bolts
Does anyone know what length the two front right bolts are?
Old 05-15-2012, 04:18 PM
Rowdy Rat
Rowdy Rat's Avatar
Are you sure that you don't mean the two front left (driver side) bolts?
Those two are definitely longer by a 1/4" or so as they had to pass through the engine lift bracket. Headmarks are typically different as well.
If you actually meant the right side, I'm at a loss... Why would they need to be different?
Regards,
Stan Falenski
Old 05-15-2012, 04:26 PM
MelWff
MelWff's Avatar
Received 1,810 Likes on 1,601 Posts
same here, whats special about right side, check this 1 1/4" for 10 and 1 3/8" for 2
https://www.paragoncorvette.com/p-35...-bolt-kit.aspx
Old 05-15-2012, 04:27 PM
mds3013
mds3013's Avatar
I think the very front bolt goes into a blind hole and the second one is open to the lifter valley? Just be careful that they do not bottom out or strike the push rods. Length depends on lift bracket also. mike...
garage-ghost
That's why I'm asking. I removed both RIGHT FRONT bolts and the front one is about 1/4 inch shorter. I thought they should be the same.
The front one doesn't look stock and I was wondering if I could put a 1 1/8" long bolt in there.
Thanks guys.
Old 05-15-2012, 05:13 PM
scottyp99
scottyp99's Avatar
Why don't you just stick something down in the bolt hole and see how deep it is?
Keep the shiny side up!
Scott
Old 05-17-2012, 05:16 PM
garage-ghost
Thanks Scotty... That's what I did, then ran a tap down there to clean out the threads and installed a 1 1/8 bolt. All is well.
To 72 LT-1 Intake manifold bolts
Quick Reply: 72 LT-1 Intake manifold bolts
