1969 l46 ?
1969 l46 ?
There were no L-46 cars build with Automatic transmission?
Somebody out there knows the truth. I'm of course guessing here.
Martin
Sounds a bit like voodoo to me. Not enough vacuum? I prefer to think the L-46 and L-79 were like the later LT-1 performance oriented small blocks and to keep up with their image they were only coupled with the Muncie 4-speed. A pure marketing decision.
Martin
Martin
You guy's are right about the vacuum. I just read an article in SuperChevy on L -79's and it said that because of the cam overlap, they could not idle properly with the stock automatic transmission torque converter. That is why the L-79 and L-46 could not be hooked up to an automatic transmision.
LS4 pilot, I know that I have read that the L-46 cam was toned down for the 69 Vette. The 68 L-79 cam is more radical. I have been looking, but cannot find the specs. for you. Maybe someone else can give you that information.
This is a page from a Hot Rod article from 1987.
The next page states that the 962 cam was the used in the L-46 and L-82 engines. It looks to me that the L-46/L-82 cam is NOT a toned down L-79 cam at all. You decide!
Pete
Pete
Pete, thank you for the information. This clarifies what I read in the past. GM changed the cam to eliminate the extreme lope at idle on the L79, but slightly improved the Max. lift and .050-inch lift degree. I have never seen the numbers compared before.
I would like to know why the article forgets the 68 corvette L79. It only lists 65-67.
Martin
Martin
