Just installed LED Dash Kit from Atlanta Speedometer
I just installed the kit in my 72 dash. Anyone considering an upgrade to their dash lighting should take a look at the package Josh at Atlanta Speedometer has developed. All hardware is included for a very simple install and the results are fantastic. It's amazing that my original 75 guages look like modern instruments! The key is that the LED ring shines from the edges directly on the gauge face. You get great illumination of the numbers and the needles seems to "float". Change colors and dim from the remote.
Mike
http://www.youtube.com/watch?v=p_9hb...layer_embedded
Mike
I'll take some pics tonight. I don't have the dash in the car yet. In the mean time check out the link I added to the original post.
Mike
Mike
Wow. That's hot. Pretty high on the upgrade list, me thinks.
I have a non-functional clock, a non-functional speedo, several wiring connections that need to be 'corrected', and a deep desire to replace the stereo, requiring an updated gauge bezel with DIN hole.
Sounds like the perfect time to update me some lights!!!
Here are some pics. I can't wait to get this car done!!!
mn_leaf_fan I tried all LEDs from Super Brite but was disappointed with the results. I AM going to use the Super Brite bulbs for my turn signal and high beam indicators. I also will try them for the 2 under dash courtesy lights.
Mike
Mike
All,
Here's the contact info for the dash kits. Good Luck!
Mike
MrJlr It connects to your existing lighting and operates as normal with the dash switch. The remote is used to change colors and/or brightness. Once set to your preferrence, you do not have use the remote.
General Info and Installation video:
http://inclusivelighting.com/Inclusi...-77_Gauge.html
Questions:
info@inclusivelighting.com
Mike
Questions:
All,
Mike
Questions:
Mike
Questions:
