1976 radio
Old 07-28-2012, 04:49 PM
white1984Z51
white1984Z51's Avatar
Default 1976 radio
Does anyone have a wiring diagram for the radio in a 1976?
Old 07-28-2012, 06:06 PM
Jerry - Radio Guy
Jerry - Radio Guy's Avatar
Way too many pages to copy and the detail would be lost. Go to Ebay and search for AR-191 which is a Sams Photofact. 75 and 76 are identical and a model 61YFM1 refers you back to 51YFM1 which is in AR-191. THat's what I use to fix them.
http://www.ebay.com/itm/PhotoFact-Au...item5883e65ffd
The two major problems in those radios are the on-off switch which is not repairable due to plastic internal parts and the audio output modules which make crackling sounds even when the volume control is fully reduced.
Old 07-21-2015, 11:50 PM
Bumby
5th Gear
Bumby's Avatar
Default Radio Repair
Do you still repair the 1976 Corvette Delco Radios. My AM doesn't work and get a lot if Static on FM stations.
Bumby
Old 07-22-2015, 01:06 AM
Jerry - Radio Guy
Bumby
_____________
I responded to you via a private message Bumby. Check that for more details. Basically, I doubt it's the radio.
That sounds much more like a broken center conductor in the antenna cable - probably at the radio connector end. My suggestion is to use a cheap aftermarket antenna (about $10) to test with before pulling and shipping the radio anywhere. If that proves out, repair or swap the cable and save a bunch of bucks for ->
_Jerry_
To 1976 radio
Quick Reply: 1976 radio
