Hood Release Cable
Old 09-22-2012, 12:32 PM
flaco1801
flaco1801's Avatar
Default Hood Release Cable
My hood release handle has seen better days...I see handles with the cable for sale..Can i just release the cable from engine compartment and replace with new handle and cable without messing with the bracket? thanks, jeff
Old 09-22-2012, 02:23 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi F,
I believe you have to buy the complete assembly including the sheath and bracket; but you can pull the handle/cable out of the new assembly and slip it into the old one.
Why not just repaint the existing handle?
Regards,
Alan
Old 09-22-2012, 05:40 PM
flaco1801
flaco1801's Avatar
Alan...i tried painting the handle but when i ised the white for the lettering it just didnt work out right..i see the handle for sale and wondered to release it from the latch and pull it out and just thread the new handle into the existing sleeve?
Old 09-22-2012, 05:57 PM
Alan 71
Alan 71's Avatar
Hi F,
I repainted my handle with good old Krylon #1613.
I used some water based white craft paint for the letters. I used a tiny brush to put it in the letters as carefully as possible and then used a damp cloth held very tightly on my finger to wipe over the letters and ended up with a very neat looking job.
Worth a try?
Regards,
Alan
Old 09-22-2012, 06:13 PM
flaco1801
flaco1801's Avatar
I tried Alan..was done and smudged the letters, (it was actually really good) i wanted it perfect....tried again and was nearly done and i lost patience.....think im gonna try the new handle and thread the cable thru the sheath,,,hope i dont regret it...
Old 09-22-2012, 06:29 PM
c69vete
c69vete's Avatar
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
I recently went through this while trying to remove some overspray from a recent repaint of my car. when cleaning the handle, I decided to remove all of the black paint from the handle, except inside the letters, (yes, it is black under the white), polish it out to a shine, and a light coat of clear to protect the finish. Not NCRS, but an option if that does not matter.
Old 09-22-2012, 07:19 PM
Alan 71
Alan 71's Avatar
Hi c69,
Not a bad look at all!
Well done!
Regards,
Alan
Old 09-23-2012, 12:11 AM
chadronvette
chadronvette's Avatar
Just had to replace mine. The only thing that comes in the replacement is the wire and handle, you just slide it through the sheath and put on the nut to hold it. Much simpler than I expected.
Old 09-23-2012, 01:06 AM
flaco1801
flaco1801's Avatar
thanks Chadron...thats what i wanted to read...the new wire was stiff enough to slide easily thru the old sheath?... thanks again,,,
Old 09-23-2012, 08:08 AM
chadronvette
Slides right in unless you mess around and bend the sheath...
The wire is pretty fine and has plenty of room so it slides in pretty easy. I was prepared for a battle. The worst part is tightening the barrel nut. I put loctite on the screw just to make sure it would stay.
Old 09-23-2012, 10:23 AM
flaco1801
flaco1801's Avatar
Thanks Chadronvette.,,yes i know about the barrel nut, i opened it up to run an emergency cable to the bottom of the chassis...
Old 09-23-2012, 10:26 AM
Alan 71
Alan 71's Avatar
Hi,
cv, you're right.
Where I first looked only showed the complete assembly, but now I see just the handle and cable is offered at other venders for less than 1/2 the price!
Regards,
Alan
To Hood Release Cable
Quick Reply: Hood Release Cable
