needing help
Unless they (GM) did something weird in 68, (ok, more weird than normal), the power motor mounts on the lower end of the regulator and has a couple of bolts that secure it to the inner panel. Check your AIM. It should show the differences if any.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Hi Ron-
The doors will work fine. Just make sure to cut the hole in the front of them for the conduit before you install them on the car. It's almost impossible to do this afterwards.
Willcox
Willcox
Canadian Events Coordinator
Received 1,469 Likes
Cruise-In II Veteran
