1969 battery cable
Received 2,127 Likes
Fred, I think it bolts to the outboard bolt of the starter. If I'm wrong someone will correct it. If you post on the C-3 side they definitely will know. Dennis
Received 1,858 Likes
I totally forgot the battery is behind the seats. duh! What makes it worse is the fact I owned a '71 for 5 years. I guess I didn't have to do anything relative to the battery cables. Memory...going going gone! Dennis
And there's another, equally important (at least to the starter) cable from the right frame motor mount to the block. All 3 connections need to be clean and tight. Electric motors (starter), are not happy with low voltage and/or low current.
