rear strut rod bushings
Old 01-10-2013, 01:18 PM
GaryBrown
2nd Gear
GaryBrown's Avatar
Default rear strut rod bushings
I am replacing bushings in rear strut rods - cannot get bottom of strut rod - closest to wheel - to go in and line up --- acts likes it is in bind - any comments on how to do this - thanks
Old 01-10-2013, 02:17 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
There's a left and a right support. D shaped hole.
Old 01-10-2013, 03:42 PM
bpassmore
bpassmore's Avatar
It seems to help when you put the strut in the wheel side first then the diff side. Raising the TA up also helps the alignment, it does not go easy.
Old 01-10-2013, 09:03 PM
GaryBrown
2nd Gear
GaryBrown's Avatar
Thanks - will check these ideas -
Old 06-27-2013, 11:46 AM
addballer696
addballer696's Avatar
having this same problem right now! uggg so frustrating. Had to come inside and take a break or else something was definitely about to get smashed.
Old 06-27-2013, 08:31 PM
79L824SPD
79L824SPD's Avatar
When I replaced mine this spring I hooked up the inside first, then muscled the shock mount ends in. Got them started in the slot, then gently persuaded them the rest of the way with a few taps of a hammer.
Old 06-27-2013, 10:52 PM
Mooser
Mooser's Avatar
Received 3,134 Likes on 2,068 Posts
I also hooked the outboard end first and then the centers.
To get the shock mounts lined up, ended up grinding a larger chamfer on the old ones (I was replacing them) to allow it to "guide" its way through everything (the "D" shaped end can be a pain) and line it up. Then removed the old mount and slide the new ones in easily.
I used the adjustable struts so the rest of my install won't help in your case.
Mooser
To rear strut rod bushings
Quick Reply: rear strut rod bushings
