Installing the rear view mirror with the map light
TheCorvetteBen
So since I am doing the interior on my 73, I decided I would swap out the small corroded mirror with a lighted mirror from a 75. Now the question is, where in the fuse box of the 73 do I plug it in?
There is a 'blank' 12V voltage spot in the center of the fusebox that runs the MSD ignition, but I believe the map light runs off've the same circuit that runs the courtesy lights (rotating the headlight switch to the left gives you that 'detent' that turns on the lights inside the vehicle even with the doors closed).
Go figure! I must've looked at not only the plastic laminated wiring diagram, but also the one in the FSM and I could not find the mirror light! I looked them over three times!!! Found the cigarette lighter, the courtesy LH, RH, Ashtray, etc, etc, glove compartment, rear compartment, my behind, but no mirror!
Mine has the mirror light and it is a single gray wire (typical Chevrolet color for instrument lamps and misc. illumination) with two connectors at the end, hooked up in series. It is not hooked up to anything, so I put 12V to it and the mirror light lit up when I moved the switch.
I also looked at the FSM for the wire layout behind the dash and I saw nothing there either. It does plug right into the fuse box though. So that's my guess and that's where I'm likely to plug it.
I dont think it plugs into fusebox...the wire runs across the header and down the windshield pillar...i think it gets spliced behind the header, i dont know what ckt it gets juice from...
I can't find my diagram, but I think it pigtails from another plug on the fuse box.
Another issue in using the 75 mirror, it is 10" long and the 73 is only 8", you will not be able to lower the visors without hitting the mirror.
Hope this helps.
Terry
Hope this helps.
Terry
TheCorvetteBen
Received 1,469 Likes
Cruise-In II Veteran
