Hwy driving
Old 02-02-2013, 09:55 AM
  #41
diehrd
diehrd's Avatar
No other alteration will bring more rewards then installing an O/D automatic in a car with a original 3sp automatic .
My car even on rural roads hits 4th and my ZZ430 clone quiets down so much cell phone use is comfortable. It has to be the best mod with returns that go way beyond MPG.
Old 02-02-2013, 02:38 PM
  #42
74 LS4-454
74 LS4-454's Avatar
Finalist 2020 C4 of the Year - Unmodified
the 82 is my "dd" and of course has the 700r4 which is great, doing
80 mph I am turing 2000 rpm's, lesser speeds = lesser r's.
And I enjoy driving the Vette no matter where, and especially on the highway which is most of my daily commute.
Old 02-02-2013, 08:53 PM
  #43
scrappy76
scrappy76's Avatar
Sorry, Have no Idea where your coming from.
Did not buy a vette for gas milage, and just to prove it I put in a big block. I did not buy a vette for peace and quiet, and just to prove it I put in a big block and added sidepipes aannd left in the 3 speed.
I bought a vette cause there is no substitute.
Old 02-03-2013, 06:32 PM
  #44
PaPaPork
PaPaPork's Avatar
can someone enlighten me with the 4speed vs 5 speed trans? I realy don't get it - if they both have only one OD gear how is the swap any good for gas millage or noise?
Old 02-03-2013, 06:37 PM
  #45
PaPaPork
PaPaPork's Avatar
Originally Posted by redwhitekat
Anyone like me hate driving on the hwy with your vette I find on my 74 4 spd if you are going 70 80 miles an hour the rpms are just so high for a v8 and car is Loud cause of the high rpms and mufflers that its just uncomfortable plus gas mileage is down the drain with those rpms so high
I hate driving mine above 50mph - the loud gear drive is a pain in the *** as well (damn bubba!), so I cycle between 3rd and neutral...
If I had an extra $2k 200r4 would go in right away!
PS. what is the lowest OD ratio available for custom trannies? they all seem to oscillate around .7 ... I wonder why? is there some kind of limit why a .3 couldn't be made?
Old 02-03-2013, 06:40 PM
  #46
diehrd
diehrd's Avatar
If you have a carb your motor would buck and stutter and shake you right out the driver seat witn a .3 OD
Old 02-03-2013, 06:43 PM
  #47
flyeri
flyeri's Avatar
4spd manual is not an overdrive trans. it has a 1:1 ratio The TKO600 is a .64:1 ratio. RPM drops 36% from 4th to 5th. Mileage goes up and noise goes down.
Old 02-03-2013, 07:23 PM
  #48
PaPaPork
PaPaPork's Avatar
I was thinking 4speed auto vs 5 speed auto, I must had not read correctly and I apologize for the confusion!
Old 02-03-2013, 08:06 PM
  #49
keithinspace
keithinspace's Avatar
I don't disagree that I wouldn't prefer a little less RPMs, but I really don't know that it does any harm to the engine. You don't think twice about running a 350, 427, or 454 boat engine at crazy RPMs for extended periods of time....
I would prefer blast up back roads, but if I need to go on the interstate, that is OK too.
Old 02-03-2013, 10:58 PM
  #50
redwhitekat
redwhitekat's Avatar
Is there a tranny out there that is 5 sp that would bolt on to my 74 4 sp
Old 02-04-2013, 09:26 AM
  #51
mark6669
mark6669's Avatar
All 74 cars got bad mileage new emission standards that year they tried everything to meet them, performance and mileage went out the window. My C3 autos all got bad mileage 30% less than same year 4 speeds.
Mark
Old 02-04-2013, 06:06 PM
  #52
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
Originally Posted by Procrastination Racing
Let me guess. You are 40 years old or less.
Probably closer to 30.
The reason I say that is your entire life has been mainly in cars with overdrive transmissions and are used to the extremely low revving engines of OD transmissions.
Remember, until 1975, highways were typically 65, 70, 75, and even 80 mph depending on the location. Some areas had NO speed limit (reasonable & proper).
You aren't hurting it.
BINGO!
Way back when, I had a '77 Pontiac Trans Am with a 4 speed manual,3.23:1 rear axle gears, and a 27" OD tire. At 65 MPH, I was looking at 2600 RPM, IIRC. My wife had a '79 C-3, and although I didn't positively know what the rear gear was, I suspect it was 3.55:1, as that car turned 27-2800 RPM at 65 MPH.
Old 02-04-2013, 06:43 PM
  #53
FastEddy
FastEddy's Avatar
Before my 5spd swap, (before 2006) I thought nothing of cruising 4,000 rpm on the highway... longest runs were 6 hours to visit my brother in Charlotte.. .and even then I didn't want to get out of the car once I got there... just wanted more...
PS - I got 65,000 hard miles out of that motor (ZZ4 crate motor) before dropping a valve from too much above 6,000 rpm high jinks one night... 3,000 to 4,000 rpms all day long wont hurt a thing as long as the fuel mixture is right.
Old 02-08-2013, 04:38 PM
  #54
MalibuVLX
MalibuVLX's Avatar
My 69 has 4:11 w/ original M-21 and sidepipes. Turns 2800 at 45mph. Just ordered my TKO600 today. Hoping for about 2200rpms at 65mph or so. I can't wait...
Old 02-08-2013, 11:59 PM
  #55
Priya
Priya's Avatar
Yes, check Kiesler transmissions.
Old 02-09-2013, 12:06 AM
  #56
JW3101
JW3101's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-‘17-‘18
Did not buy a vette for gas milage, and just to prove it I put in a big block. I did not buy a vette for peace and quiet, and just to prove it I put in a big block and added sidepipes and left in the 3 speed.
Notice the license plate!
I don't worry about the gas mileage and enjoy the sound of the pipes. The radio is worthless as you can't hear it.
Old 02-09-2013, 12:45 AM
  #57
Learning_Curve
Learning_Curve's Avatar
A 200-4r can be picked up used and rebuilt for half that cost.
As far as overdrive ranges, a T56 six speed manual has a .5 6th gear. But it is a not quite "bolt in". I picked one up myself for 2000 dollars, and got the car that it came in with it...
To Hwy driving
Old 02-10-2013, 02:48 AM
  #58
PaPaPork
PaPaPork's Avatar
Curve, thanks for reply, THe t56 would be sweet with the 0.50 OD but I heard that the pedal space is pretty tight in manual applications? (never had a chance to sit in a manual C3) I do fine in a large Benz with a stick but I have 15Extra Wide shoe size so it might be a problem
Old 02-11-2013, 04:29 PM
  #59
Brown78
Brown78's Avatar
Tremec 5 speed. Fifth gear is 0.68
Old 02-11-2013, 05:23 PM
  #60
demoke
demoke's Avatar
Just drove my 1980 4/speed from Charlotte NC to see my family in Savannah, Georgia. About 600 miles round trip and she handled awesome. It was such a great feeling taken the tops off on Saturday(65 degree day) and hitting the highway. I made a great playlist on my Ipad, put the earphones on and headed south. Even though I have headrs and side pipes I was not bothered by the low hummm coming from the 380hp rebuild. This type of trip is good for me mentally and physically for my car. The wife had other plans for the weekend so I was on my own. I just returned home, and even though it rained on my return trip, my 80 still handled great. Lots of looks and waves along the way was an added bonus. Can't wait to do it again. Spring is almost here. Now I have to go and get to scrubbing.
Quick Reply: Hwy driving
