Front drag tire leaking at bead.
Old 02-06-2013, 05:14 PM
540 vette
540 vette's Avatar
Default Front drag tire leaking at bead.
I have a set of Mickey Thompson front runners and Centerline wheels. They are new, never used. I have them for about 3 years and they leak at the bead. I can't see any problem. It is happening to both tires. Should I put tubes in them, do they even make tubes for them.
__________________
Old 02-06-2013, 06:13 PM
Redwing01
Redwing01's Avatar
2015 C3 of Year Finalist
You need to remove the tires , clean the rims and use as sealant when you reinstall the tires. Aluminum rims are known for oxidization and leaks.
Old 02-06-2013, 07:57 PM
TimAT
TimAT's Avatar
WE used to run a bead of the same glue around the bead we used to put patches on the inside of the tire. Worked everytime.
To Front drag tire leaking at bead.
Quick Reply: Front drag tire leaking at bead.
