69 rear window weatherstrip
Old 02-12-2013, 08:10 AM
Jim Myers
Jim Myers's Avatar
Default 69 rear window weatherstrip
Installing a new weatherstrip around the rear window on my 69 coupe. Someone had done it before and really messed it up. They had cut most of it off after it had been glued in wrong. I have a new weatherstrip and it appears that it will be difficult to get it to stay in place while to glue is drying.
Has anyone accomplished this and did the window fit properly after installation?
Old 02-12-2013, 08:29 AM
MrJlr
MrJlr's Avatar
I need to do this too.....I don't even know how to REMOVE the glass....got any tips ?
Old 02-12-2013, 10:05 AM
Raphiki
Support Corvetteforum!
Raphiki's Avatar
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
'69 rear glass is a lot different from '74 glass. The '69 us removable. I did my '70 a few years ago. Cleaned everything up real well, dry fit the weatherstrip and marked it along the way so I knew everything would line up the same. I then started gluing it all together a short stretch at a time using tape to hold it all in place.
Old 02-12-2013, 10:17 AM
MrJlr
MrJlr's Avatar
Oh dang.....forgot that '69 was removable.....
Old 02-12-2013, 08:46 PM
loup68
loup68's Avatar
There are a couple of screws on each side to help hold it up. Use tape to hold the weatherstrip up. Glue a litle bit at a time and tape it in place. Test fit it dry, first. Lou.
Old 02-13-2013, 06:09 AM
Jim Myers
Jim Myers's Avatar
Thanks, Lou
To 69 rear window weatherstrip
Quick Reply: 69 rear window weatherstrip
