Chazde3's '68 Vette Project
#201
Nam Labrat
Received 4,156 Likes
It's good to hear your dad is still handling things......a new frame!
#202
In 1973 they changed the front bumper. Back bumper section is the same, I agree. I cannot speak for the front bumper changes and I don't think they show that on this example. Front bumper when from 72 metal bumper to 73 rubber bumper, so that may or may not work for your 68. Need someone to crawl up under a 68-72 front end, and then the 73 front end, and get some pictures for you. The brackets have to be different and how they mount may be as well.
The article referenced only details the rear of the car from what I can see.
Anyone out there got some other pictures?
David
David
Ah yes, dad's retirement fund at its best lol. Money in the bank he used to say when hauling all sorts of parts home.
#203
Senior Member
Received 2,031 Likes
St. Jude Donor '10
Ah yes, dad's retirement fund at its best lol. Money in the bank he used to say when hauling all sorts of parts home. [/QUOTE]
In many respects I think your dad was correct Chuck. No falling interest rates, no exchange rate fluctuations, no lack of demand for quality corvette parts, and very few reliable sources of quality GM parts makes what your dad did appear very wise. We needed more visionaries to help assure the future of our now aging antiques. Glad you have those to rely upon when you need them.
I am working to do some of the same now, but maybe not to the same scale.
David
David
#204
6th Gear
So being the car is a 68 vette I noticed that it does not have the push button 68 only thumb button on the door. So does that mean it was changed to a newer year door lock mechanism or is the door newer? Just an observation. I'm just curious because lots of stuff is 68 only and thats not a 68 door lock, this is.
#205
#206
The 68-74 frame is basically the same. The 73 and 74 front bumper brackets were made to fit up to the old frame. I think that in 1973 they added the rubber body mounts, so the mount points are lower than the 68-72 solid aluminum mounts. In 74 they added two small brackets on to the rear outside edge of the frame.
I purchased a replacement GM frame for my 68 and the two small brackets at the rear were the only difference, and I removed them. I hope that this information helps you. Lou.
#207
#208
Senior Member
St. Jude Donor '10
Thanks! These seem to be all the changes that I have found in my research as well. I can manage modifying the bumper brackets to work and use the rubber body mounts. Next up is figuring out how to unbury the frame, arrange transportation to my home garage and begin building a rolling chassis. I need to purchase a car trailer so I can help clear out junk cars at the parents house and eventually use it to trailer this car when I need to, just have to sneak the money past the boss.
Best regards,
David
#209
Oh god, I'm already freaking out about imperfections in the paint job as is. I'm meeting up with the local G8 club in a couple weeks and she isn't ready and I don't have much free time to get the swirls out before then. I have a short bed F150 I could strap it to, but I'm not a big fan of getting pulled over
#211
Senior Member
St. Jude Donor '10
Very kind of you to offer David. I have a slightly different idea to run past you as long as my mom would approve which I don't see as being a huge issue. I will get a hold of you later about this.
I'm home now through the end of the month so fire away when ready sir. I just drug a 1981 coupe home with damage to the front end so I have a toy to play with for a few days. It will keep me busy enough for the next couple of days. David
#212
#213
vette
Like the avatar! Your dad would be proud of that.
#214
Nam Labrat
#215
I'm picking up an engine hoist and leveler after work tonight and dropping them off at the garage on my way home. I'm hoping to get the engine out of the car on Sunday. I also need to figure out a cheap set of wheels so that I can roll the car around. Planning planning planning.
#216
Senior Member
St. Jude Donor '10
Thanks guys! I figured after 2 years here I should probably toss an avatar on. Oh and I forgot to mention, I came across the matching fender vents from the other side digging through the garage a week ago. I need to get that one cleaned up so that I have the matching set finally.
David
#217
#218
Started the engine break down
3904392 heads
3933163 intake
Stuff that made it into the engine over the years
Where I quit for the night
3904392 heads
3933163 intake
#220
Nam Labrat
VALVOLINE?
MICE?
MICE?
