What glue to attach carpet to rear compartment
Old 04-24-2013, 11:54 AM
toolman0114
toolman0114's Avatar
Default What glue to attach carpet to rear compartment
I put new carpet in my 74 last year and noticed the carpet is coming unglued from the rear compartment doors.
I use 3M spray adhesive, but that's not holding.
What should I use to glue these down?
Old 04-24-2013, 12:42 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Unless you use a good quality contact cement, the weight of the carpet on that back wall will cause it to come loose. The factory had 3 rubber plugs that held the rear carpet panel up and against the rear wall. There are holes in the body panel for them and you can buy those plugs from most of the Corvette aftermarket suppliers. If you use the plugs, the 3M spray adhesive should work fine.
Old 04-24-2013, 12:47 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
I used the 3M and haven't had any problems with it. Fitting the frames over the carpet and around the doors was the PITA.
Old 04-24-2013, 12:54 PM
toolman0114
It is only the lids on the rear compartments where am I having an issue.
Old 04-24-2013, 01:01 PM
7T1vette
7T1vette's Avatar
Carpeting on lids should be cut to fit the door, not the inside area of the frame. If the sections are already too small to be retained by the frames, use contact cement on door and carpet, then press together. You may need to clean the 3M goo off, first. Use lacquer thinner...or "Goo Gone", if you don't care to lose any more brain cells.
For those who are attempting this and have not yet cut the carpet pieces too small, cut them to fit the door panels. Then, shave down the carpet knap along the edges, where the frame will need to compress the carpet. If you can't easily install the screws for retaining the frames, get a piece of plywood (at least as big as the frame) and clamp [hand operated squeeze clamps or C-clamps] the frame/carpet/door assembly together to put the frame in correct position to insert the retaining screws. Insert the screws, then release the clamps.
Old 05-13-2013, 10:46 PM
jnealg
jnealg's Avatar
I am also having rear deck carpet glue issues.
Maybe someone can post a pic of the carpet surrounding the astrovent in a non AC car.
It looks like the PO just threw the carpet in and didnt trim for the vent doors.
Is it common to have to trim carpet around the vents or does it come pre cut correctly (i am doubting)
I will have to look for the plastic plugs and glue it back up cause it wants to flop down currently.
To What glue to attach carpet to rear compartment
Quick Reply: What glue to attach carpet to rear compartment
