1975 vette won't start
Old 05-20-2013, 08:04 AM
andyo
Navigator
andyo's Avatar
Default 1975 vette won't start
I drove car, parked, came out 5 minutes later, turned key...nothing. cables are good...tryed jumping...nothing.....popped clutch and started and drove home....checked starter and it would not do anything on the workbench...changed starter...still the same...changed 3 wires at the starter, one was fusable link...nothing....Any suggestions?
Old 05-20-2013, 09:37 AM
Raphiki
Support Corvetteforum!
Raphiki's Avatar
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
Have you checked the ground between the engine block and the frame?
Old 05-20-2013, 10:34 AM
andyo
Navigator
andyo's Avatar
yes
Old 05-20-2013, 10:40 AM
Raphiki
Raphiki's Avatar
did you bench test the new starter?
Old 05-20-2013, 10:45 AM
my 76 ray
my 76 ray's Avatar
Check the safety switch on the clutch.
Old 05-20-2013, 11:20 AM
andyo
Navigator
andyo's Avatar
yes
Old 05-20-2013, 11:22 AM
andyo
Navigator
andyo's Avatar
I'll give that a shot....seems I can disconnect the switch and wire direct to see if it starts??
Old 05-20-2013, 06:03 PM
my 76 ray
my 76 ray's Avatar
Yep
Old 05-20-2013, 07:22 PM
Raphiki
Raphiki's Avatar
Just be careful so you don't run your a$$ over!
Old 05-20-2013, 11:20 PM
The Punisher
The Punisher's Avatar
Fuseable link. ? Had the fuse able link get corrosion on the connector by the firewall and it did the same thing your describing
Old 05-21-2013, 07:53 AM
andyo
Navigator
andyo's Avatar
I'll try that..Thanks
To 1975 vette won't start
Quick Reply: 1975 vette won't start
