C3 78 Paint adventure
#44
Ok.... After some sanding and more sanding, finally I got it to look about right, it is a little light, but any heaver and it would turn color.
after 2 coats, waiting for third, it looks good......I will be glad to get the plastic sheets down and open up the garage again.
#49
How much time did you wait between spraying the clear onto the basecoat. Some basecoats have a 24 hour window before you have to put another coat of color on.
#50
I waited 24 hr's before staring clear, it also required 5 min wait between 1st & 2nd...but 24 hr ...light sand w/800 grit.for 3rd.
Products used....Evercoat Feather fill, Medallion NO Sand primer, Wanda Base coat, Medallion European clear coat. I found the instructions simple to follow.
Although It said I did not have to wait between coats & applications, I preferred to wait before moving from one application to another just to be sure it was coming out OK.
#51
As you can see in the above photo lot of orange peal. Once I sanded it down for the final third coat,, the temps dropped....We will not have those warm days for awhile we are mid60's to low 70's.....When it was 105 - 120 this summer I had to put the paint I the refrig.
to keep it cool enough to apply.....Now I have to heat up the garage and put the clear coat in the house to warm it up...I did not know this part of it, but I should thought of it...Now that third coat looks worse than my first attempt....Re-sand and start again.
#52
it looks good to me, i just pushed it in at all the corners and edges best i could and then put the car out in the sun, the heat will make it conform to the body, it will eventually lay down and flatten out. i didnt use any glue.... on my 79
#57
Beautiful color! I plan on painting mine C7 Atomic Orange. Next time you might try fogging a light coat over the whole car to even the colors out after assembly before clear. For me seems to work very well with the high solids colors. Very nice first paint job tho. Your "paint booth" looks just like mine
#59
Not trying to derail your thread but I was beginning to wonder when we would see the finished product. I knew you were having trouble with the heat of the day causing different patterns.
I am now very happy to see a beautiful re painted C3 like no others. I know your'e proud of the final products, as well you should be. Its one of the finest looking C3's I have seen. Keep up the great work and good luck with the finished product and keep us posted.
Bill
Bill
#60
Douglas,
What an adventure you have had! As someone who started custom painting 10 years before this car was built..I can honestly say I feel your pain
First time and you picked one of the hardest colors, you did well.
If you are going to resand and buff wait until you have everything else done that you are going to work on.
Gary
Gary
