Need close-up pictures of 1980 L48 a/c mounting brackets/locations
I pulled the a/c mounting brackets off for my cam install and am having some trouble getting them mounted back where they belong.
If anybody has photos of the a/c compressor mounting brackets and mounting points, please post them here. I'll check back daily.
Much appreciated!
Much appreciated!
1 Post
St. Jude Donor '16-'17,'19
Here's my '81 pics. Looks like you may already have what you need and I'm not sure how much mine will help anyhow. If you need more or anything else I can do to help let me know.
edit: i just reread your post in my thread. I didn't comprehend your question too well. I don't recall seeing a lower metal rod. When I get back home i'll take another look and see if I can get some pics from the lower side if you still need them.
edit2: yeah, it looks like you have what you need in the thread that KapsSA linked.
Whoever took those pics is a hero! Thank you for re-posting them.
As is arklacat - thank you very much.
And don't forget the 1/4" or so spacer that goes between the ac bracket and A.I.R. bracket(if you have the pump) @ the water pump bolt.
That A.I.R. bracket isn't shown in the links posted.
Thanks for all the good info. I removed the A.I.R. pump with this project.
looks like i'm missing that top bracket, does the other end bolt to the intake manifold
