Replacing a std Steering column with a Tilt column
I've purchased a Tilt/Telescoping column to replace by standard column in my 1972 Convertible. Both columns are 1972 Corvette columns. Is it a straight swap? Thank you, Tim
Yes they are a straight swap. One thing to keep in mind.
The ignition switch on your new T&T column operates in the opposite direction from the ignition switch on your non-adjustable column that is being replaced. You will need to twist the two connectors 180 degrees on your vehicle's wiring harness in order for them to snap into the T&T column switch.
I hope that you were able to purchase the turn signal switch lever, the tilt lever, and the horn and telescope hardware along with the column.
This is a blowup of a 1977-82 T&T steering column telescope lock and horn hardware. The components may not be exactly the same as the components on a 1969-75 T&T column. But all of them are required.
Good luck,
Jim
Good luck,
Jim
Good luck,
Jim
Jonathan
I just completed the exact same swap. The two plug wires that plug into the silver box on top of the column plug in upside down from what they were in your standard steering column. They only fit one way but you will notice they go in different than your old column. Mine worked perfectly on the first try.
Good luck,
Jim
Good luck,
Jim
After taking out the original column, which I was doing other work anyway, it took me about 30 minutes to figure out how to get the key assembly moved over. The new column just goes right into place like the old one and the existing wires blog right in. I hadn't done it before so there was extra time getting it in position for the firewall plate and bolts but now I can do it quickly.
