Paging Van Steel - Spreader Bar ???
Hey,
Is the front shock tower bar listed as Van Steel P/N VS-42222 clear the water pump pulley and engine driven fan. In other words on a stock engine pulley setup is it a bolt-on installation? I see others need alignment and welding etc. I don't mind that but am looking for a bolt-in.
John
John
mine was bolt on and went on with no issues.i have a flex fan but that should not make a difference in your case.good luck a great cheap upgrade.sb l 48.
It looked bolt on just making sure. I can weld but it's been a while and don't feel like it or paying someone to do it.
This product actually surprised me. It must be new. Every time before I've seen the other style in the other parts book. Just thought I'd check Van Steel since I've had such good luck with them in the past and found this.
BTW I have a flex fan on an Edlebrock aluminum water pump.
