Factory Correct Seat Belts For 68-82 On Sale **Starting At $184.99!**
Former Vendor
St. Jude Donor '12-'13
We've partnered with the largest supplier of reproduction seat belts in the country to offer C3 owners factory correct seat belts at huge savings.
We have kits for a 68 to a 82 with pricing starting at $184.99 for an economy set and options to upgrade to the GM replicas.
Click here to browse our huge selection, we know you'll find the set you've been looking for to complete your restoration.
http://www.corvettemods.com/Seat-Bel...nts_c_282.html
I work for and handle the Corvette Mods account with this Seatbelt Manufacture. Call and place your order with Corvette Mods and ask him to request the additional length you want and we'll build the belts longer for you. We build every set of seatbelts to order so it's no problem at all.
I'd also recommend checking into the Premium/ OE Styled belts for your '78 since they come with the OE styled tongue with the metal tongue cover along with GM buckles and new buckle sleeves. The economy belts have a plastic tongue cover, no sleeves and a regular buckle.
Eric
Eric
Former Vendor
Eric
Eric
Former Vendor
Medium Saddle (3008)
http://www.corvettemods.com/C3-1972-...le_p_8103.html
I looked closely at you 73 convertible OE set and they look to be very close reproductions at a reasonable price.
Glad to see that these are offered!
Also glad to see that the convertible shoulder belt conversion is also being offered. I don't know that I've seen this available as a set before. Well done.
73 Seat Belts and rollup needed
My rollup for the drivers lap seat belt does not function. The belt is fully out and the re-tractor does not pull it back into the rollup. Do you have the hardware or a repair kit?
Is it possible to get a shoulder belt that attaches to the factory lap belt in a '69? Mine are reversed from the repro setups: The hole to hook the shoulder belt is on the lap belt, and the hook is on the shoulder belt. If the correct configuration isn't available, is there an adapter? Don't really have a need or desire to replace lap belts.
The underseat retractors are a common failure and most of the time it's corrosion related from interior leaks and rainwater. Your sounds like the spring has failed which can oftentimes be repaired however I've never seen a repair kit since the spring has to be preloaded during the installation.
1969 (Late '68 also) was the only year that came with the shoulder belt mounted on a vertical plane and the shoulder belt had the stud on the underside and the slot in the tongue. Since 1970-73 coupe/convertibles and 1974-75 Convertibles have the stud on the tongue and collar on the shoulder belt we produced this set up on our aftermarket reproduction belts.
One option is refurbishing your belts but from the sounds of it you may not need this. Do you have a shoulder belt? or wanted to add one?
Eric
I had hoped to add a shoulder belt to my convertible. Most of the belts, though, don't come in dark green, so I didn't really care to replace the whole mess. Mine are in good shape. All I really wanted was shoulder belts of whatever color--probably black since green isn't out there. I would think that someone, somewhere, must make a shoulder buckle piece with the stud on it. Maybe its possible to just cut off the pieces that comes on it and sew on the proper one? Hmmm....
The short and direct answer is, No.
Eric
Eric
Do your seats have the shoulder belt guides or are you adding those? Also pull back the carpet in the back where the wheel well hump is located and look for factory threaded mounting holes for the retractors.
We carry a Saddle and Medium Saddle that should be what you can use for the Dark Saddle interior. Here is a color sample but again this is only used on the OE Style belt sets.
