Diff Drain Plug...Magnetic?
Old 08-27-2013, 08:51 AM
CAMS69
CAMS69's Avatar
Default Diff Drain Plug...Magnetic?
While doing my frame off resto on my 69 I found the original diff drain plug with the plastic red warning label attached to it. It was sitting on top of the diff cross member in the pocket. The diff plug that was installed is magnetic but has no way to hold the label. Do I need a magnetic plug? I'm not doing a NCRS resto but I like that tag. What do you fellas think?
btw there was a few very small pieces of metal attached to the magnet , like 2 smaller than a grain of sand..
Old 08-27-2013, 04:51 PM
MelWff
MelWff's Avatar
Received 1,816 Likes on 1,605 Posts
Personally I have the magnetic plug and think it's of more value than having a tag.
Old 08-28-2013, 09:44 AM
71scgc
71scgc's Avatar
As high as the diff fill plug is, I don't think a magnetic plug would do much good. When I had my diff rebuilt, a real drain plug was installed in the bottom of the carrier. Here's what it looked like when I changed the lube @ 500mi as recommended by the builder:
To Diff Drain Plug...Magnetic?
Quick Reply: Diff Drain Plug...Magnetic?
