How to test a voltage regulator?
Old 09-08-2013, 02:41 PM
1978vett
1978vett's Avatar
Default How to test a voltage regulator?
Is there any way to test the voltage regulator ? It's a 78 corvette. Thanks
Old 09-09-2013, 09:32 AM
1978vett
1978vett's Avatar
Anyone??
Old 09-09-2013, 09:43 AM
Hammerhead Fred
Hammerhead Fred's Avatar
Diode trio check
Rectifier is tested the same way.
Old 09-09-2013, 11:06 AM
Mike Ward
Mike Ward's Avatar
Given that the regulator is integral with the alternator, take the unit to your FLAPS and have them test the whole thing.
Old 09-09-2013, 11:14 AM
bpassmore
bpassmore's Avatar
Reference page13-15 reply #3 for the test of the regulator by grounding the regulator test tab through the D shaped hole in the rear of the alternator, if it is defective the voltage will not change if not it will go to full out put
To How to test a voltage regulator?
Quick Reply: How to test a voltage regulator?
