Can any here post pics of the brackets for attaching the AC compressor with headers?
Old 09-24-2013, 08:17 AM
TheSaint
Support Corvetteforum!
TheSaint's Avatar
Default Can any here post pics of the brackets for attaching the AC compressor with headers?
I wonder how the AC compressor brackets ment for use with headers looks like when the compressor installed in the engine compartment
Great if any here can post some picture of how the brackets/compressor assembly with headers looks like it would be great
I have a C2 but i am pretty sure a picture of a C3 with headers AC brackets is just the same
Old 09-25-2013, 03:26 PM
MelWff
MelWff's Avatar
Received 1,816 Likes on 1,605 Posts
look at the two brackets on this link, go to the detail and look at the instructions, they have diagrams.
http://www.summitracing.com/search/b...ader%20bracket
Old 09-25-2013, 03:34 PM
v2racing
v2racing's Avatar
I don't have photos, but on my 80 all I had to do was make a spacer for the bolt hole that goes to the one of the exhaust mounting bolts and slot the hole in the AC bracket.
Old 09-26-2013, 04:32 PM
TheSaint
TheSaint's Avatar
Looking at the picture from the instructions for the bracket used for attaching the AC compressor it is only the rear of the compressor it holds?
I found the picture to the right of a 1972 Corvette doing a image search on google
Old 09-26-2013, 05:24 PM
toddalin
toddalin's Avatar
Received 1,167 Likes on 486 Posts
This appears to use the bolt holes in the head, as a C3 would. Got those or are you running stock heads?
Old 09-26-2013, 08:38 PM
jbrown8238
jbrown8238's Avatar
NE Events Coordinator
Here's how I did my '79
Jim Bondy (04-05-2022)
Old 09-27-2013, 05:16 PM
TheSaint
TheSaint's Avatar
Great Thanks for the help
I know how fasten the compressor using headers i hope
Old 09-27-2013, 09:03 PM
outlawkinser
outlawkinser's Avatar
This is how I modified the AC bracket on my '74 when I installed my Hooker Super Comp headers.
Mike
Old 09-28-2013, 03:52 PM
TheSaint
TheSaint's Avatar
outlawkinser. Thanks for posting
The diagram is copied and stored on my computer
Old 09-28-2013, 07:00 PM
toddalin
toddalin's Avatar
Maybe you could take a regular alternator "F bracket" and grind the welds out to separate it back into two pieces. Then you could cut some length out of the rear section and reweld the two pieces back together at the right distance and use a Header Power Bracket just the same way that you would mount an alternator with headers.
Typical alternator F Bracket:
Extended right side Header Power Bracket with Smooth Satin Spacer:
Old 09-29-2013, 12:20 PM
TheSaint
TheSaint's Avatar
Toddalin. I suppose that might work
I have an old alternator bracket i can cut the weld on and check if it works with the Header Power Bracket i have(have not put the Header Power Bracket on the car yet)
Old 10-08-2013, 01:29 PM
TheSaint
TheSaint's Avatar
I found this picture of an alternator bracket posted of a forum member some time ago that i had stored on my hard drive
I wonder if this bracket can converted to be used as a AC compressor bracket?
Not sure but i think this bracket may be a one only bracket but guess something like the bracket can be made for the AC compressor as well
Old 11-02-2013, 08:16 PM
TheSaint
TheSaint's Avatar
I thought that the brackets was attached to the head but here i see how the front bracket is attached
Great that the front bracket is attached on the water pump
Is it usual to use 2 screws like on the picture to the right?
Old 11-02-2013, 10:17 PM
ezobens
ezobens's Avatar
Where does one get one of these 'Header Power Brackets'?
Old 11-02-2013, 10:32 PM
toddalin
toddalin's Avatar
Can get them here.
http://headerbracket.com/
Old 11-03-2013, 08:32 AM
ezobens
ezobens's Avatar
Can get them here.
Awesome- Thanks!
Old 11-04-2013, 04:59 PM
TheSaint
TheSaint's Avatar
Is it original with 2 bolts(i thought that it was supposed to be only 1 bolt)that holds the belt to the bracket after you have added tension to the belt?
To Can any here post pics of the brackets for attaching the AC compressor with headers?
Old 11-21-2013, 07:01 PM
TheSaint
TheSaint's Avatar
There are no holes in the heads for any brackets on my car
Old 11-23-2013, 09:14 AM
TheSaint
TheSaint's Avatar
I found this picture for the AC compressor brackets for a C3
Are these brackets original for a C3?
There are no holes on the head on the engine on my car i can use for AC brackets and the fact that i have headers
What about using these brackets on a C2 or will the compressor be mounted to far forward?
Looking at the picture to the right it looks like that bracket is fastened in one of the water pump bolts and also the right side head
Old 12-06-2017, 05:12 PM
dlopeman
6th Gear
dlopeman's Avatar
Hi guys! I recently joined (today) and I also recently purchased an 81 Vette from a friend... in pieces!!!! I mean... all piece were in boxes: interior, engine components, etc... all that was "in" the car was the block/headers. Everything else, pretty much, I had to assemble... well the suspension was in it, actually...
Anyway - it's almost all STOCK, except that I changed the intake to a Torker II and an Edlebrock carb. Oh - and it has headers instead of exhaust manifold... which I'm sure all of which affect answers to my questions below. Read on:
So... I'll get to the point, I promise! The bracket all made sense for assembly with a little trial and error and spacers and whatnot. However, I showed a mechanic buddy of mine the engine bay one day, and he said that the AC Compressor needed more support. So I poked around GOOGLE and landed upon the pictures TheSaint posted here showing the metal "bar" brackets. Once I saw this, I was like "Hold on! I saw these in some box somewhere!" and I found them. However... I cannot find WHERE they are supposed to attach. I'm going to dig out the old stock quadrajet intake and see if there was a mount point that not on this Torker II. But then there that one that goes from the bottom of the bracket to somewhere near the fuel pump on the block. I can't figure that one out, for sure!! I may not even have that metal-bar-bracket.. I have three. Only one I was able to finagle a hook up over to the thermo housing... not sure what good it may provide but figured something is better than nothing.
So maybe some of you have a similar set up (it's not really unusual, right!? Edlebrock carb, headers, intake... pretty typical "upgrades" IMO) Maybe there are some better aftermarket brackets I should consider for my recipe. I don't mind about stock/nonstock stuff. As long as it works and works well!!
I'll get a picture uploaded so you can SEE what I'm describing.
As always, TIA.
Quick Reply: Can any here post pics of the brackets for attaching the AC compressor with headers?
