Three... two... one... lift off!
Received 19,234 Likes
'20-'21-'22-'23-'24
Awesome project you are undertaking. Best of luck as you continue the restoration.
lift off
Looks like everything is moving along. Just started removing things from my 69, lift off I hope for the weekend. Hope it goes as well as yours. Thanks for the pics
Regards R
Regards R
Shop helpers
Thanks everyone! No doubt I'll need a shop helper, say an American Welder
As for the English Mastiff, it's a sweet idea but for now I have to content myself with seeing my friend's occasionally (below).
Next phase: build more storage shelves. I ran out of room...
89corvettemann (02-19-2024)
Hmmm... that dog looks familiar - a bit smaller than mine, but quite familiar
PB Blaster to the rescue
After a two week hiatus because of freezing temperatures and a bronchitis, I am back at it. Removed all gas and brake lines, steering system and front suspension.
That big bolt on the top left was real seized. 24 hours after PB-Blasting it, it came off easily.
Naked front:
Still need to take out those 4 arm shafts:
More pictures under December Teardown.
Next step: dismantle the rear end.
With all that physical exercise I have lost 5% of my weight since the beginning of the project. I'm so thin you can see through me now. Need to increase my calories intake...
Thanks for taking a peek.
Naked front:
One seized bolt after another
Made some progress in the last week, trying to tear down the rear suspension. I'm facing a bunch of seized bolts, real nasty ones. Got my first impact wrench to help out (580 ft-lbs) - my garage sounds more like a pro shop now :
This is how I compressed the rear spring:
And voila:
Got the differential+spring off as a whole, on a transmission jack:
I bet separating them will be a challenge (4 bolts).
The remaining bolts (not the nuts) are as frozen as can be, including the infamous trailing arm bolts:
May the force be with me.
And voila:
The heat will be on
Indeed and so is apparently an employee at our local O'Reilly store. He recommended that I use my dinky propane torch from Harbor Freight, heat up a seized bolt as much as possible, and while hot spray it with penetrating oil and bang it. It will suck in the penetrating oil while cooling down. I'll give this a shot.
ctmccloskey (07-26-2020)
Winning formula
How to combat a frozen shock absorber mount: (Heat + Spray + Bang) x N, N > 3
Two battles won this afternoon:
I might try one of my wife's many candles on my garage mistress one of these nights.
#34
Built an entire vette in 10 minutes
Today's my birthday and SBG came over and said now that my vette is quasi-dismantled I need to practice rebuilding. So he challenged me with this birthday gift:
I'm happy to declare that I passed the test:
I feel more confident about my project now, although I'm a little concerned because this model is a '78 and my vette is a '77
Happy New Year to everyone.
#35
Anyother victory of mankind over steel
A little update: I was expecting trouble with the 4 bolts connecting the rear spring leaves to the differential but luckily they came off immediately with the impact wrench:
No such luck with the trailing arms! I had to buy a sawzall and cut through the bolts. Took a total of 17 blades:
As you can tell I tried to get the shims out first - it just would not happen:
On the passenger side too:
Next challenge: remove the differential crossmember with the 'sombrero' bushings.
Thanks for taking a peek!
#40
So basically, it'd have taken me less time to totally disassemble the car to cut those bolts out than try to cut them out with the body on... good to know
