Gas fumes when in garage
Old 10-06-2013, 11:54 AM
Martyjax
2nd Gear
Martyjax's Avatar
Default Gas fumes when in garage
We have a '77 and when we drive it it runs good but when we park it in the garage we get terrible gas fumes that filter into the house thru the a/c unit. When parked outside there is no odor of gas. Any suggestions.
Old 10-06-2013, 12:14 PM
John 65
John 65's Avatar
First thing that comes to mind is the charcoal canister, or lack there of it, that is located under the washer fluid tank in the drivers side fender. Perhaps its missing or hoses are no longer hooked up.
Edit. I would also recommend getting a 77 AIM and make surel the correct plumbing for this is there and in good shape if this turns out to be the problem.
Old 10-06-2013, 01:10 PM
tokim
tokim's Avatar
The bigger issue is why does your a/c unit circulate gasses/air from your garage throughout your house? If you had a fire in your garage, it would also circulate it through your house.
Very dangerous, call in a HVAC specialist, and seal it off properly..do it now!
As far as why your car smells of fuel when shut off, could be many reasons..inspect for its source (noticeable leaks under car?, fuel inlet, fuel pump, charcoal canister, etc.).
Old 10-06-2013, 01:23 PM
russianhomie119
russianhomie119's Avatar
check the rubber hose lines coming off the tank where they connect to the hard line. mine were cracked and leaking gas and I didn't even know it
Old 10-07-2013, 07:39 AM
LudemJo
LudemJo's Avatar
I have the same issue. Mine seems to be worse when the fuel tank is full. I started looking yesterday, and found that there is a fuel/vapor separator mounted on the tank, and it has two hoses running from it. One hose routes fuel back into the tank, and the other hose hooks into the steel lines that route up to the vapor canister. I seem to get a heavier smell of fumes at the back of the car, so am going to look at that more closely. Unfortunately getting at it may be difficult since it is mounted to the top driver's side of the tank. This may have to wait until winter when there is a good chance that I am going to replace the fuel tank since the current tank has quite a lot of surface rust. Inside looks clean though. I'll let you know what I find when I can try to stck my head up there to look at the separator and hoses. The hose going to the steel line does look like it needs replaced, so that will probably be my first order of business if I can reach it.
John
Old 10-07-2013, 10:42 AM
Revi
Revi's Avatar
Have you checked the fuel cap gasket, they fall out and into the tank on occasion.
Old 10-07-2013, 01:18 PM
russianhomie119
John
Its fairly easy to drop the tank, and if the inside is good you could paint the exterior with silver por 15
Old 12-05-2013, 11:26 AM
Brians1
Support Corvetteforum!
Brians1's Avatar
I have same exact issue on my 81...my charcoal canister is currently disconnected (Guy I bought it from took it off)...Sounds like I need to conenct it back, my fumes dont leak into the house but im paranoid they will and I have a 2 year old in the house so I'm even more paranoid...plus wife would kill me if the house got any kind of smell in it LOL.
on my 81...does it go in same location? Driver side...and I should see some lines (rubber or steel) hanging there? ** I hope they are capped off...maybe not and thus my heavy fuel smell....?
Old 12-05-2013, 12:06 PM
Kacyc3
Kacyc3's Avatar
Are any of you guys using braided steel line for fuel on your cars?
Old 12-05-2013, 12:24 PM
Brians1
Brians1's Avatar
I am not -all factory setup to a factory Rochester Q-Jet
Old 12-05-2013, 01:54 PM
Vettereturned
Vettereturned's Avatar
I installed a braided line from the frame rail to carb. (electric fuel pump).
Old 12-05-2013, 01:58 PM
Easy Mike
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
Originally Posted by Brians1
...on my 81...does it go in same location? Driver side...
Pretty much.
...and I should see some lines (rubber or steel) hanging there?...
Hopefully, but that depends on what the PO left you.
The assembly instruction manual (AIM) shows how the canister is installed and how the lines run.
Old 12-05-2013, 10:23 PM
M A Fry
M A Fry's Avatar
I was having the same problem with fumes. I found out recently when I had problems with my sender unit, that myy rubber fuel line that connects to the sender/fuel pickup had started to perish.
Old 12-05-2013, 10:55 PM
dgr72vette
dgr72vette's Avatar
The separator is a ball valve and if it fails gas will run to the canister instead of just fumes if parked on an incline with a full tank
Old 12-06-2013, 12:42 AM
doorgunner
Nam Labrat
doorgunner's Avatar
Received 4,153 Likes on 2,726 Posts
AHAAAAAA! So...charcoal cannisters aren't evil after all---just the checkvalve.....that explains the 6 ounces of gasoline in the charcoal canister!
I don't need the gas smell in the garage, either. Time to order replacement parts!
Old 12-06-2013, 12:50 AM
Iceaxe
Iceaxe's Avatar
Received 2,606 Likes on 1,393 Posts
X2
Mine was a very small leak and the fuel would evaporate before dripping to the ground, it was kinda hard to locate because it was so small. But it would sure make the garage smell of gas.
Old 12-06-2013, 01:05 AM
kdf1986
kdf1986's Avatar
I had a 73 with the same heavy gas smell. After doing a lot of the checks suggested, mine turned out to be the lines that go from the tank to the steel lines on the chassis. This is by the passenger side muffler. They were cracked and leaking a little bit of gas, but giving off a lot of smell.
kdf
To Gas fumes when in garage
Old 12-06-2013, 07:36 AM
tmd442
tmd442's Avatar
Yes, That was my problem also.
Old 12-06-2013, 08:35 AM
Easy Mike
Easy Mike's Avatar
Originally Posted by doorgunner
...So...charcoal cannisters aren't evil after all...
Never have been. They prevent fuel vapors from venting to the atmosphere.
Old 12-06-2013, 09:28 AM
joewill
joewill's Avatar
my vote is rubber fuel line hose at the fuel pump is leaking. that is the point where there is movement in the hose from the engine movement bouncing around. especially if you have a weak or broken motor mount.
Quick Reply: Gas fumes when in garage
