My 1973 Frame off Follow along the Restration
#281
That looks good. Did you just weld in a piece of sheet metal, bend it up, and drill the hole based on the good door you've got? I don't have a welder, but there is a weld shop in town that could probably help me out.
#282
Yes I did that but did not cut the shape until after it was in place. Took measurements from the good door.
#283
Senior Member
Received 2,031 Likes
St. Jude Donor '10
Looking good Tim.
Tim 1973 (03-27-2017)
#284
I'm going a little off topic as I have spent the last week working on my auto-hauler. I used it a few weeks ago for moving some items for work and noticed how bad the Texas Sun has beat it so decided to blast it and get it painted. I also decided to put line-x on the bed.
I picked it up yesterday from line-x now I just need to paint it and put the polished diamond plates back on. I also decided to change all the lights to led so it will be like new when done. I bought it in 2003 and has been a great trailer.
#285
I did some painting of some small items today. I have a question for those that have put bodies on a frame. How difficult is it to put the body on with radiator installed? The reason I'm asking is I want to start my engine before I marry my body and frame. this would mean i would need to add antifreeze. after I do this I would rather not remove it after insuring I have no leaks.
I picked up a car Rotisserie last week so I can start working on the undercarriage. I need to replace both seat belt reinforcement plates. Once that is done its off to line-x to spray the undercarriage.
I'm headed out of town (Seattle) on the 23rd so I need to get as much done in the newt 2 weeks.
#288
Did some painting of small parts last night. Today I got off work early and decided to install the rear sway bar.. Need to purchase the rear calipers and brakes pads...
#291
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
A friend and I are looking at getting one together.
Txs
Dennis (Bman)
#292
http://www.gregstowingandequipment.c...gory-s/223.htm
Above is where I got it. $795.00 I will be making the mounts copying how David did his on the following thread.
https://www.corvetteforum.com/forums...as-sought.html
Once I finish using it I will likely put it for sale. Hope that helps
Tim
Tim
#295
#296
Ask away, I travel a lot for work so sometimes es its a few days before I get back on here. There are a few projects always going on in the form so try to follow as many as you can to get ideas.. Good luck and they are a lot of fun to do....
Tim
Tim
#297
I powder coated my tail light assy white gloss, then painted the outside with black. The white should reflect well and hold up to the weather.
#298
Tim
Tim
Keep me in mind when you are done with the rotisserie. Timing might be right to sell/buy it.
I looked thru David's thread but with 34 pages I could not find where the rotisserie cam into play. Any idea what pages it was on?
Txs again
Dennis
#299
Thanks Tim......great info.
Txs again
Dennis
Txs again
Dennis
When I sell it I just want to recoup 90% of what I have in it. I will start building the frame for the rot when I get back from the Pacific North west . If you follow this thread you will see it. Once I have the the body on the rot it will only take a few weeks. then back on the frame for the final time.
Tim
bmans vette (04-13-2017)
#300
I have a few days off this week before I head to Seattle, I took Radiator to welder to get the top fan mount welded. I do not have the gas and wire to weld aluminium and only need it once in a while so have a welder close to me that is reasonable.
I'm assembling the front for the last time. Once together I will fill the radiator check for leaks and start engine for the first time.
