door glass blowout clips
Old 10-10-2013, 09:30 AM
vettestu
vettestu's Avatar
Default door glass blowout clips
are these things really necessary. before I go fabing up a new pair?
Old 10-10-2013, 10:06 AM
4SPDL81
4SPDL81's Avatar
St. Jude Donor '16
The clip holds the glass in place when both windows are up and one door is closed... when you shut the opposite door...it prevents the glass from being pushed out of its channel by air pressure...good luck!
Old 10-10-2013, 02:59 PM
DickieB
DickieB's Avatar
Also, if you are cruising at 75 mph and try to roll the window up, the glass is pulled outward, and tries to go outside the rubber channel.
Old 10-10-2013, 03:57 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
They are 8.55 a pair? Pretty cheap vs. making a set.
http://willcoxcorvette.com/advanced_...eywords=PILLAR
To door glass blowout clips
Quick Reply: door glass blowout clips
