Turn signal and backup lights don't work.
My turn signal and backup lights are not working anymore. I checked the fuse and it is good. What other parts can cause this problem?
Turn signal switch
Backup switch
Turn signal switch
Backup switch
the turn signal, backup lights work off the same fuse (20a), check to see voltage is present at fuse box terminal.
http://www.corvetteforum.net/c3/tune.../index11.shtml
Received 1,468 Likes
Cruise-In II Veteran
Bulbs.
Flasher for the turn signals.
Switch adjustment for backup on 4 speed cars. Neutral safety switch for auto trans cars.
