Painting aluminum radiator
Cruising
I just got a Dewitt's unpainted aluminum radiator with the plan to paint it myself. Does anyone have a recommendation for a paint brand? I was thinking a flat finish or possibly satin. Thanks!
Wouldnt the radiator transfer heat more efficiently if left unpainted and is there any drawback to leaving it unpainted?
Nam Labrat
Received 4,176 Likes
Here: http://www.eastwood.com/eastwood-rad...ack-paint.html
Received 1,469 Likes
Cruise-In II Veteran
Received 2,683 Likes
Paint Preventing Heat Transfer
I hear this all the time on forums that painting engine components or in this case a radiator somehow inhibits heat transfer. Well, I am not an engineer but I think it sound like B.S. Harley Davidson has been painting their air cooled engines for years, way back to the early days. Considering they have always had to deal with heat, it would seem unlikely they would paint the cylinders if it truly had an affect on heat.
Same with our 350 engines, GM painted the entire engine, and I intend to paint my aluminum cylinders and intake manifold, and don't believe it will make an ounce difference in engine temperature.
Yes, I have an opinion. Don't do it. You will only help to insulate those fins so that the radiator is less efficient. You would be better off just CLEANING the fins with something that will not damage/eat them.
But, that's only my opinion....
Paint the tanks...paint the fittings....don't paint the fins.
Former Vendor
I'm going to agree with you on this one People post their gut feelings but have no real data to back it up. It sounds logical that paint would reduce the heat transfer of a radiator but the surfaces that you paint to not transfer heat. It is the tube-to-fin area that does this and it's almost impossible to coat that area but the paint goes right through the core. We've painted many radiator and cut some open to see what happens inside and there is no coverage where it counts. The only way to could hurt a radiator performance is if you were to dip paint the radiator. This would soak up a lot of paint and clog the core.
Do you have a recommendation on what type of paint to use? Does it make a difference?
Former Vendor
It is the only paint will bond to the aluminum and never peel off. This formula also can be used on bare steel, without the need for primer, for suspension parts. The simply mix equal parts A and B, wait 15 minutes, and spray with a spray gun. Clean up with laquer thinner
I'm just trying to figure out WHY one would want to paint the radiator fin area (if not already painted)? In a C3, you can't really see any of it, unless you have the hood opened; and then, you can only see the rear of it...or the part that is visible via openings in the radiator shroud.
Paying $40 [or, for that matter, anything!] smacks of trying to sell someone a book titled "HOW NOT TO BE GULLIBLE" for ONLY $39.95. You buy the book and open it only to find out it has only one line of print:
"You shouldn't have bought this book."
Former Vendor
