hood release
hood release
hello, can anyone tell me if they make a tool that will unlock the hood release on the c3 vets. my 75 coupe hood release latch cable broke when I tried to open the hood. the hood is now locked down. I know of the small hole in the firewall by the windshield arm on the drivers side which is suppose to let you have access to the latch. is there a certain tool used to do this or the plain and simple screw driver will do. thanks scott
Received 2,878 Likes
hey Alan thanks for the reply. unfortunately when I purchased the car it came with no manuals and I have been stupid in not getting manuals on my own. on the 75 coupe I don't think I can get it that way so I will have to try the long screwdriver method
again thanks for the reply
scott
scott
Over the years I have had too many hood latch cables end up in my hand after the cable broke. Once you do get access to get it open, I suggest you connect a coated cable to each side and hide it in the cowl. this will insure that it will never break again, but will give you peace of mind..
I used a 1/4" steel rod apprx two feet long, bent it to fit through the latch hole and away from the windshield. Works great. I also carry it with me when I travel. Once you get the hood open, fine tune your latch tool and notice where the hole is - for next time.
