Frame paint
Frame paint
I am planning a body off restoration and I am wondering what people have using for frame paint. Also, it is my understanding that the frame is a satin to semi gloss finish.
Nam Labrat
Received 4,173 Likes
Paint finish depends on whether you are staying with a factory finish (do an internet "search").......... or not (the finish is your choice)
As for the quality of paint, you can DIY it.......or have it painted....
with anything from Rustoleum to powder coating.
I used two-stage urethane paint on mine and it's held up pretty well, but if I was going to do it again, I would powdercoat it.
Received 2,878 Likes
Received 1,469 Likes
Cruise-In II Veteran
If you seek authenticity, consider adding the effects of weather. Frames were stock piled outside the building at St. Louis. It is very possible your new frame was rained or snowed on before being brought inside the building and delivered to the chassis line.
I used POR-15. I also blocked off all of the holes in the frame rails and threw a quart in each one. Sloshed it around for about 45 minutes (throwing it around your lawn on a hot Florida summer day is great exercise!) and pretty well covered the inside of the rails too.
Powder coat is the only way to go will look like new for several times longer than paint. It seals the cracks to prevent rust from creeping out. You can paint over it as Alan stated for a correct restoration.
Mark
Mark
Anywho... I powder coated my frame and I love it. Wasn't expensive either. I used Eastwood's Semi-Gloss chassis paint on the snadblasted suspension parts; it's a really close match.
As learned here by Alan 71, it would depend on the year of your car. Earlier (pre 72?) methods used an asphalt coating that was not too heavily applied. It wipes off easily with mild scrubbing, using simple green, don't ask.........
Hi,
I'm thinking the change from an asphalt based coating to an enamel based paint occurred for 70 model year?
Regards,
Alan
Regards,
Alan
