Wheelbase measurement possible without suspension on frame?
Is this possible to do accurately? I am doing a c4 suspension swap on my 82 frame.
Have any of you done this that can help? I have the 82 front suspension but not the rear.
Received 2,878 Likes
Hi my,
Some one with the trailing arm off the car needs to measure the distance from the centerline of the forward bolt hole on the t-arm to the center line of the stub axle.
You'd then measure back from the centerline of the t-arm bolt hole in the frame to locate the center line of the rear axle on your frame.
I think this could be done in a pretty exact manner with the t-arm off the car. Too much of a guess on the center line of the axle shafts when the t-arm is mounted.
Maybe?
Regards,
Alan
Maybe?
Regards,
Alan
Hi my,
Maybe?
Regards,
Alan
Maybe?
Regards,
Alan
Were these arms the same from say 69-82?
Hi my,
Yes they were!
Regards,
Alan
Yes they were!
Regards,
Alan
