1970/1971 Alternator part number
Hi, does anyone know when GM made the switch from 1100900 to 1100543 alternator number? I own an early 1971 pre 4000 (Sept 1970 build date) and have a found a 1970 alternator but with a 1100900 number not 1100543 (which is for a 1971). Most of the original parts in the car have an August date code. Could it be possible that GM may have used a 1100900 alternator toward the tail end of 1970 production vehicles? Again my car was assembled in Sept 1970 so it makes sense that a lot of my parts have an Aug date code.
Definitely possible. GM would have used left-over stock for "general" items like the alternator...if the one for the new model year was very similar and interchangeable. Some model change items are "MUST" changes; others are "USE" changes.
Received 1,469 Likes
Cruise-In II Veteran
Most of the original parts are coded the first two weeks of Sept. Block is first week of Sept, the proportioning valve (t-valve) on the breaks are Sept 13th 1970. My guess is that assembly started in Sept then postponed mid Sept through part of Oct. Car rolled off assembly line first week of Nov. 1970.
