correct radiator and shroud?
Still going through the car and finding things that don't look quite right. Does the radiator and shroud look correct for a 75? The upper bracket is much wider than the radiator but the rubber insulator looks right because it reduces down in size to fit the smaller width of the radiator. I know that the car has some 76 and 77 parts on it so I am trying to inventory what I will eventually fix. The radiator shroud has a cut out section in the bottom where it meets the frame cross over, not sure if it shows up in the pictures. From what I can see in the catalogs and AIM it looks like it should be a continuous piece all the way around.
I have a '75 and just removed my shroud from the car and the gap at the top seems to be the same as mine, along the sides are the rubbers.
The fan shroud itself, I'll post some pics maybe you can see what you wanted.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
What part number is on the shroud? Knowing that will make this easy. The Aim part number was 342247, however it was replaced by 339175.
Willcox
Willcox
